Brake line question
Started by keith88, June 23, 2014, 08:59:54 AM
keith88
Hi i will be putting in a new propositional valve in after i finish the nose on the charger I could not get the old cast iron one that i had on the car so i had to order the newer 2 brass block set up and was wounding if anyone knew of a place that made a brake line kit for it or do i have to make my own. One of my biggest issues i can see already is that some of the lines are going to require different size fitting on each end of the line. :scratchchin:
1969 Charger  Orange /black top  (1989) 360 engine stock with added xtreme comp cam and a 4 bbl  , 904 trans/shift kit , 8-1/4 rear.. with general lee accents.
Mopar Nut
terrible one
From my experiences with each of them, I have to recommend Fine Lines over Inline Tube.  :Twocents:
Mopar Nut
Quote from: terrible one on June 23, 2014, 06:30:31 PM
Good to know, here's Fine Lines.
http://www.finelinesinc.com/
Mopar Nut
Ok, I just read this about Fine Lines, I wondering if stainless lines are worth it.
http://www.dodgecharger.com/forum/index.php/topic,111435.msg1282891/topicseen.html#new
hemi68charger
Quote from: Mopar Nut on June 24, 2014, 02:35:18 AM
Sometimes there are issues with the seating of the line unto the flare seat of the fitting. Stainless is more rigid. Make sure you have a real good fitting flare-nut/line wrench so you can put some force behind the tightening without rounding off the flare nut.
Houston Mopar Club Connection
will
With the amount that these cars are driven, and the fact that the original lines lasted as long as they have, why go stainless? It's a pain in the ass to work with and requires different fittings. Plus there is the added expense. I went with original lines because they bend easier if you have to, no kinking. Plus you can flare new fittings if you have to. I did buy stainless for fuel, might go EFI in the future.
keith88
Made my own out of nickel/copper line Came out OK considering its my 1st time doing this. Only had couple leaks that i was able to fix quickly.
