dumb timing ?
Started by lasvegas69charg, January 13, 2013, 12:16:57 PM
lasvegas69charg
I know i should know this but just to make sure, on my 383 i turn the dist CCW to advance timing correct?
69 dodge charger 383/727/3.55 (my dad is the original owner-matching number) stroked to a 496😉
no...turn it CW to adv advance timing
Bryan
lasvegas69charg
71 SE3834V
Rather then trying to remember which way to turn it I found it best to look at the vac advance and see which way it pulls the breaker plate to advance the timing then turn the dist the same way. This way no matter what kind of engine, with a vacuum advance, you will know which way to turn it. I hope that makes sense. Trying to figure out another way to explain it. I could look at any dist. w/a vac adance & tell ya but don't know if I'm explaining it right.
71 Charger SE 383 4V
72 Galaxie 500 400 2V
