c body tie rods
Started by flyinlow, January 01, 2013, 11:44:46 AM
flyinlow
Just to conferm , c body tie rods and sleaves will work on a 1970 Charger?  What year c body?  Do they help?
HPP
Yes, they fit. The taper on the end links are identical to other body styles. As far as I know, any year will work. The theory is that their 11/16 diameter is stiffer than the smaller 9/16 diamter of other styles, therefore they deflect less and provide more precise steering.
IMO, the split sleeve design between the ends is the offending piece, not necessarily the size. A 9/16 tie rod end can withstand 5g worth of loading, so stepping up to 11/16 just adds weight. Replace the split sleeve with a solid sleeve and the 9/16 ends will perform just fine.
