440 help
Started by Mar10n83, December 19, 2012, 09:24:16 AM
Mar10n83
hi
Anybody have any ideas for better performance on my 440?
the motor seems to be stock inside, but got the edelbrock 1407 carb and the CH4B intake.
Looking for a everyday driver with some performance :)
Thanks for a great forum :D
metalstorm440
useualy a cam change is easy hp from a stock engine.A .509 cam will useualy fit also if the heads,block have not been milled.A wide lobe seperation like 112 intake center line will help you also with valve to piston clearance and avg torque.
areibel
Welcome!
Are you just looking at bolt ons (carb, intake, exhaust), or are you thinking more like head work, cam- the package approach?  Or a tear down and rebuild?
There are several excellent builders on here, let us know what you're looking at and get started!
Mar10n83
Mostly looking for bolt-on parts since buying the car kinda broke my wallet  :icon_smile_cool:
With the setup i got now theres no "kick" in the engine, and i also suspect that the kickdown wire isnt setup right...
cdr
Quote from: Mar10n83 on December 19, 2012, 06:13:09 PM
get that linkage checked out NOW if it is way off the tranny will get roasted,also it just might need tuning to get it to kick better ,,,,a bad tune can make a 600 hp motor run like its 400 hp   :Twocents: :Twocents:
