haywire tailight
Started by greyeagle, November 07, 2012, 08:34:20 PM
greyeagle
im new to this board so here goes  i bought a 68 coronet and the flashers were not hooked up no blinker signal no nothing. so i got all that stuff hooked up and new flasher and all but front right flasher works after messing with it for a few hours and still not gettiing it going i noticed my back left flasher not working. taillight, brake light work just not the blinker.front left and rear right blinkers still work. any ideas i would sure like to hear them
twodko
If you haven't already done so, go through all the connectors and makes the contacts are clean. Where ever you find a ground wire, unscrew it and clean it.  :Twocents:
Cooter
Shake the Turn Signal switch up and down/in and out at the column. most times these get corroded and cause a "No worky" situation.
greyeagle
Ok I will try these things the switch is brand new but I will take the wheel off and make sure things are right
