Inner axle seal?
Started by Crazy440, September 06, 2012, 10:43:53 PM
Crazy440
Never installed inner axle seals. Which side of the seal goes in first? And how do I install, without buying the installation tool?
I used to have a handle on life....but it broke off.
the bottom picture goes in first...you should see a little spring in there, that goes towards the center of differential
note: pack the inside of the seal with grease before installing, the grease will stop the little spring from popping out when you drive it in with seal or a race installer
Bryan  (don't ask how I know this)
Crazy440
The seal goes in the end of the axle tube, correct?
Plus, I don't see a spring.  These came with a Green bearing set.  And as you can see, in the pic., no spring.
randy73
No spring and yes they go in the tube. When you take the axle out you will see a little ridge about 2.5-3" inside the tube. The seal butts up to the ridge, with hollow side facing inside.
471_Magnum
They are a little tough to remove since the are.so far in the tube.
I just got done replacing the outer seal and bearing on one side. I'll be doing the inner seal before.reinstalling the axle. What a PITA getting that bearing off...  I'll wait until the other side leaks before I mess with it.
