mopar intake
Started by darkside, August 19, 2012, 12:59:42 PM
darkside
Anyone running one of these?looks like a performer rpm.I wonder if
a stock magnum air cleaner on this intake will fit without hitting the hood ?
http://www.jegs.com/i/Mopar-Performance/312/P5153525/10002/-1
BSB67
It is the Performer RPM
11.68 @ 120.2 mph
And as far as hood clearance, it will likely interfere if you dont use a drop base air cleaner.
darkside
i'll hold out and try and  find a action plus.
You sure?  They're a great piece.
 tell you what would be a good idea , & why they not thought of it !! put the installed hight on the box , / web sites ,  with the hight  of the stock iron intake  :yesnod:
quite fancy buying  that intake  & using  it  , with a new cam grind  i want to try  :scratchchin:
Here is my torker 383 intake, 1 inch spacer, 4779 holley, standard base cleaner with filter top. All fits under the stock hood. Also have solid motor mounts so I st a hair higher there too. The performer can't be taller thn a torker
He's talking about using the stock air cleaner though.
71bee
Wonder if that intake & a stock air cleaner housing will fit on a 383 with a '71 bulge hood? anyone try this?
Back N Black
i have the stock unsilenced air cleaner with the RPM intake, i used a ford drop base.
darkside
Quote from: Back N Black on August 22, 2012, 01:23:36 PM
do you have a pics of that?
Back N Black
Quote from: darkside on August 23, 2012, 04:20:36 PM
:cheers:
darkside
Did you grind off the Edelbrock logo and rough up the area to hide the evidence before painting?
Back N Black
Quote from: Ghoste on August 24, 2012, 03:28:03 AM
Nope, i also have Edelbrock heads and very few people ever notice.
I saw the heads looked too smooth to be stock but I couldn't see the eddy logo in the pic. Very nice sleeper look.  :2thumbs:  :2thumbs:
darkside
the new  mopar wedge intake looks sweet .
