tire size
Started by hawkeye, August 17, 2012, 06:52:26 PM
hawkeye
found these rims on craigslist.  two are 8x15 with 3 1/2" backspace and the other is 10x15 with a 5 1/2" backspace.  need tire suggestions. thanks hawkeye
cdr
295 50 15 for the rear,235 60 15 for the front
twodko
That would be a sweet combo......I second the suggestion. Do we have a quorum for a full vote?
hawkeye
any clearance issues with these sizes?  thanks hawkeye
cdr
Lennard
Brass
A little wider in front:  245/60/15 and 295/50/15 in back.  Both would be about the same diameter; somewhere around 26".  Though 3.5" is not a lot of backspace up front.
68blue
Running 265/60/15 front, 295/50/15 rear all 8 inch rims.
Mopar Nut
Quote from: 68blue on August 23, 2012, 08:43:28 AM
Can you post some pictures of the 295/50/15 on a 8" wide rim?
Quote from: Mopar Nut on August 24, 2012, 07:13:32 PM
See here...
http://www.dodgecharger.com/forum/index.php/topic,69757.0.html
Mopar Nut
Quote from: Just 6T9 CHGR on August 25, 2012, 07:07:27 PM
See here...
They fit good, nice looking wheel.
