TC problem
Started by randy73, July 29, 2012, 07:29:44 PM
randy73
Putting my 46rh behind my 340 just hit another snag, only 3 bolts on the TC line up. My options are pulling the TC and sending it back or drilling out the bolt hole to make it fit(what I want to do), but will that throw the balance off?
I turned the TC trying to see if maybe that one was off for a reason, but no matter which way I turned it, there was alwats that one off.
FLG
Dont start drilling, get the right one.
95 and earlier ones had one hole offset, so try rotating it a few times. If it still does not line up its possible your one of your components is 96+ (which has symmetrical holes) and one part is older with the one off set hole.
randy73
The engine is a 73 340, so I am confused by what you said. It is a 95 46RH, so do they make a symmetrical 46RH lockup Torque converter?
I did try rotating the TC, still no good.
FLG
Yes. 96+ cars had symmetrical TC's
randy73
Quote from: FLG on July 30, 2012, 09:50:57 AM
Thanks and will a 96+ work in a 95 46RH?
Quote from: randy73 on July 30, 2012, 09:44:26 AM
Are you aware that the '73 340 has a cast crank that requires external balance weights on the converter or a special flexplate?
randy73
Quote from: John_Kunkel on July 31, 2012, 01:09:34 PM
Yes, Chryco told me that and I ordered my TC with weights.
