6-pak help needed
Started by Sendero, July 14, 2012, 11:49:50 PM
1974dodgecharger
WOWzers...and this all for an increase of 15 to 20HP?
mauve66
hemi performance and better manners
Robert-Las Vegas, NV
NEEDS:
body work
paint - mauve and black
total wiring
PW
PDLKS
Tint
trim
alignment
Sendero
Update: We pulled the fore and aft carbs. The back carb had one of the idle mix scews 1/2 turn from bottom. The other barrel was closer to 3.0 turns.
Fixed that. My brother also adjusted the float level on both outboards to just under the site plug rather than half way upper some write-ups  and we checked the fuel bowls for the remains of the Holley plastic site plugs ( nothing found...must have completely disolved in the gas). Bolted everything back up and the engine fired up and appeared to idle well for a short time. The MP gas lines were leaking like a sieve so we shit down. My brother is buying a new MP set then we will be able to see how it is really running.
rt green
how did you come out when you got everything fixed?
third string oil changer
