daytona on ebay
Started by cdr, July 14, 2012, 08:01:34 PM
cdr
Indygenerallee
I think that car is here in Indiana
Quote from: cdr on July 14, 2012, 08:01:34 PM
    there is a bracket bolted to the rear valance next to the tail pipe what is it for ?
I think it's the transport tie-down brackets? It has 2, one on each side
Bryan  (I could be wrong...usually am)
hemi68charger
Quote from: Indygenerallee on July 14, 2012, 08:08:04 PM
It is.. That's my friend's F6.. Nice car.......
Houston Mopar Club Connection
Lighthorseman
Beautiful car.  LOVE that F6!  :drool5:
Mytur Binsdirti
Quote from: A383Wing on July 14, 2012, 08:30:03 PM
I doubt it's a tie down bracket as there is no hole in it for a hook to go through. I don't know what the real purpose of it was, but every 68-69 Charger has them. On a separate but related note, that picture shows quite a lot.
f6f6f6daytona
The bracket is the tail pipe exhaust hanger.....if you look closely you can see where the chrome tips slide into the rubber receiver holder which Is connected to that bracket.....very hard piece to find, at least for me it was!!
Yes, by the way....this is MY car!!!
moparstuart
Quote from: f6f6f6daytona on July 15, 2012, 06:11:47 AM
love the car  so wish i could afford it    :drool5: :drool5:
held1823
Quote from: moparstuart on July 15, 2012, 06:42:18 AM
ditto. i'm checking last night's lottery tickets as we speak.
look for an edit of this post, if one of them hits...
Ernie Helderbrand
XX29L9B409053
WINGIN IT
I thought the OP was talking about the bracket polted directly to the bottom the valence panel where you can see the head of the bolt.
Is this the chrome tip holder? It looks like that one is farther back.
moparstuart
:rofl:  pretty easy to find i just looked in my trunk
odcics2
Not the original hood.
mauve66
sweet color and pretty cheap considering, seller bought a fiberglass nose in 2008, wonder if its on the car?? doesn't matter though , i can't afford it :brickwall:
Robert-Las Vegas, NV
NEEDS:
body work
paint - mauve and black
total wiring
PW
PDLKS
Tint
trim
alignment
f6f6f6daytona
Yes, top of the line Janak nose!!!  All original guts......Original was too far gone to restore to the standards of the rest of the car....
resq302
For what its worth, I think the hook part that someone was talking about was the V shaped part which also gets attached with the exhaust tip hanger.  Someone told me over the years that was where the jack was supposed to go but I have never needed to try it out to see if that is where you would jack up the car.  Either way, I have only used my jack once and it was to change out a tire going flat.  If it were up to me, I'd NEVER use one of the stock jacks.  Too unsturdy and way too much can happen with a bumper type jack.
Brian
Quote from: WINGIN IT on July 15, 2012, 08:11:20 AM
this bracket?
Bryan
cdr
Quote from: A383Wing on July 15, 2012, 04:08:48 PM
this bracket?
Bryan
YES
WINGIN IT
Quote from: cdr on July 15, 2012, 05:33:34 PM
this bracket?
Bryan
YES
What he said  :yesnod:
Mytur Binsdirti
Here's a couple pictures of said bracket on my car. What purpose the "hoop" portion serves is beyond me?
Indygenerallee
I have often wondered what purpose that bracket served as well! When I tore into my 69 I looked at them and I can only take they were afterthought to stregthen the back valance to frame area?!  :shruggy:
hemigeno
I think the hoop portion of the bracket could have served as a rear tiedown point for the car during initial shipment, using a "J" hook that would fit into the recessed portion of the bracket.  The bracket didn't have a hole that went all the way through, since doing so would have allowed the chain or hook to make contact with the exhaust tip and would have undoubtedly damaged it while in transit.  I don't think the hook would have slipped out as long as the rear tiedown chains were crossed or at least angled towards the center of the car - but I could be wrong entirely.
The front of the car was tied down via a hole on the vertical face of the front frame rail, forward of the front tires.  Frank Badalson and I had discussions about whether it was appropriate to put some scratch marks on the frame at that location, showing the transporter's tiedown evidence.  (incidentally, I wouldn't recommend regularly using those holes or the rear brackets for your own hauling's tiedown points, since the metal is only lightly reinforced in that area of the frame - Chrysler needed it to hold for one trip on the transporter only).
:Twocents:
elacruze
That is actually a bumper to save the valence and fuel tank from contacting the roadway such as leaving the gas station-ask me how I know.
1968 505" EFI 4-speed
cdr
THANX GUYS i have figured it out! they are wheelie bars :smilielol:
cdr
part of the problem is they should be under the valance,just looked at my car & they dont hang down near as low as this cars
