9.25 rearend question
Started by bad_habits, July 06, 2012, 02:33:41 AM
bad_habits
I have a 9.25 rear in my 74, and the front pinion seal is leaking. I have the new seal, but thought I'd ask if there was any specific way to change it or its just a matter of spinning the bolt off and removing it to change the seal. I don't know much about rear end pre-loads and wanted to make sure to do it right. Thanks
I would center punch the pinion & nut to get the nut back to the same place , the torque will be around 200-250 ft lbs , I do not believe they have a crush sleeve in them
Scaregrabber
They have a crush sleeve. So you'll need one of those as well and a torque wrench.
Sheldon
roadrunner440
u shouldnt need a new crush sleve or am i wrong if u mark the pinion n nut?
once you release the pressure the crush sleeve never works again , you can try to retorque to the marks & see what happens but I bet you will be installing a new crush sleeve , it takes a lot of torque to crush them
roadrunner440
how will u know in unsure of exactly wat the crush sleve does besdes holding pinion in place
Plumcrazy
Here's what you need to do.
Remove the brake drums and disconnect the driveshaft.
Measure the turning torque of the yoke. Then remove it and replace the seal.
Reinstall the yoke and tighten the nut until the turning torque is between your original measurement and up to an additional 5 inch pounds of torque.
bad_habits
Ok thanks for the replys, so is a new crush sleve required or not?
it keeps the correct pressure on the brgs .
the way Plum Crazy is telling you to do it no .
