Oil Change question
Started by BananaDan, June 24, 2012, 10:35:54 PM
BananaDan
So I changed the oil today for the first time since she's been back on the road (third oil change actually but I didn't do the other two myself).  When I had the engine rebuilt I went with the MP extra capacity oil pan, which I'm told is 6 quarts including the filter?  It seems to jive because the oil I took out just about filled up the 6 empty quart bottles when I was done.  The interesting thing is the dipstick reads add 1 quart, I have a standard repro dipstick.  I'm thinking that the standard repro dipsticks don't read accurately for the extra capacity oil pan?  I wanted to check because I am pretty sure I don't need to put another quart in her, but maybe I do?.  If my suspicion is right, do they make a dipstick for the extra capacity oil pan?
I put in Valvoline VR1 Racing Oil, 20W-50 with a bottle of ZDDPlus additive.  The oil pressure gauge seems about the same as it was before the oil change.  It reads about 40 idling and 50-60 while driving, accounting for the crappy accuracy of the stock gauge of course.
Dan
BananaDan
I just did some reading on this site and it seems that the pan is a 6qt. pan and the filter is on top of that so it should take 7 qts. and I guess the dipstick is accurate.  I guess it is 6qts. plus the filter, not 6 qts. with the filter.
:shruggy:
6qt pan, plus one for filter
Bryan
Quote from: BananaDan on June 24, 2012, 11:19:15 PM
:shruggy:
yes as we discussed :thumbs:
BananaDan
Yep, thanks for sorting me out.  I'm good.  I guess it was too good to be true that a case of VR1 would provide me a nice even 2 oil changes.
resq302
Dan,
FYI - I use the VR1 race oil also that has the added zinc.  I was told not to use any zinc additives if I used an oil with the high zinc content in it as it could be more harmful than good.  Too much zinc could cause problems my engine friend said.  He said that the VR1 has enough of the additive zinc so you wouldnt need any extra.
Brian
Fred
Brad Penn  SAE grade 20W-50 is another good oil with plenty of zinc in it. It's what I use.   :2thumbs:
440
I've always had good luck with Royal Purple although some don't like it for whatever reason.
Fred
I've tried to find out the zinc content in Royal Purple with no success. They don't seem to want to divulge this info so I'm a bit skeptical.
Quote from: 440 on June 25, 2012, 10:58:00 PM
Maybe because its double the price of the VR1 ;)
BananaDan
Hmmm.  Has anyone else heard that adding a zinc additive to a high-zinc oil like VR1 could be a problem?  I told Mike Bonsanti (my speed shop) that and while he did say it wasn't needed, he didn't say it would cause problems.
:shruggy:
resq302
I remember reading it somewhere through one of our members in the NJ Region AACA who brought a published article to a meeting with the need for the zddp additive and in the write up it said that while not enough is a problem, too much can add up to problems too.
Brian
Dan, you'll be fine....I'd be more concerned with the fact that you were a qt low ;)
bill440rt
Quote from: Just 6T9 CHGR on June 27, 2012, 08:42:02 PM
:iagree:
Just don't use the zddp next oil change if you don't have to, or if there is sufficient zinc in the VR1 oil already.
Fred
Quote from: resq302 on June 27, 2012, 08:20:33 PM
You a right.
Dan, you won't hurt anything by adding a bottle zzdp additive to 6qts of VR1 oil.  ;) The Hemi repro pan holds 6 qts plus whatever the filter holds. I allways used 7 qts and called it good   :icon_smile_big:
BananaDan
OK, thanks all.  I'm leaving her as-is and will add the extra quart this weekend.  I guess I have two bottles of ZDDPlus left that I won't need...   :shruggy:
Paul G
I add one bottle of ZDDP with 8 quarts of VR1. I have read that even VR1 does not have the same amount of zinc that regular oil used to have back in the day.  The more you research ZDDP, the more confused you will get. I did.
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
Fred
It's mind boggling alright.  :scratchchin:
Brass
Quote from: Paul G on June 28, 2012, 09:04:17 PM
Which is why I use Brad Penn 10/40 and call it a day.  Formulated with the right amount.
bill440rt
Quote from: BananaDan on June 28, 2012, 06:08:59 PM
Psst...
I'll take 'em back off your hands, Dan.  :2thumbs:
I run bradpenn 10w40, but every person posts a different oil analysis that says the other guy's oil doesn't have enough additive. So I run a bottle of zddp in my car as well. No wiped cam and I put a lot of miles on the car. With the 10w40 I sit at 85lbs oil pressure cold, at temp I sit at 40 idling(1300), 60 cruise(2800), 80ish at (7000)
Fred
Does anybody use Brad Penn 15w-40?. I'm very curious. It's never mentioned.
I have used Brad Penn oils , seems like a good product  :2thumbs:
Fred
Yes it is a good oil, I use it myself but I use 20w-50 and was just curious as to whether anybody acually used the 15w-40.
I've never used the 15w40. It was a few bucks more then the 10w40 and I don't drive the car in the winter. The 20w50 caused waaaayyyyy too high oil pressure. It pegged my 100 lb oil pressure gauge. Even the 10w40 has to warm up before I cruise. With my oil cold it will get way too high on the gauge until I'm up to operating temp
Fred
Quote from: c00nhunterjoe on June 29, 2012, 10:03:34 PM
That's really interesting. I don't have that problem with mine. My oil pressure is perfect with the 20w-50.
It all depends on how tight your engine is. My tolerances were very tight. I wind my engine up around 7k so I wanted everything close. I put it together in 2000 and its held up with no work other then oil changes and a carb upgrade.
resq302
My oil pressure has always been pegged although it does have the high pressure spring in it and I also run 20w-50 VR1 synthetic in it now.  Is there any problems with having that much oil pressure in the system?
Brian
If nothing else, it robs horsepower.
Fred
Using the 20w-50 B.P. my oil pressure by start up goes up to 80. Once warmed up and driving at speeds of 62mph it sits at 65.
resq302
Im confused, how does high oil pressure rob horse power?  I know the thicker weight oil does but high oil pressure?
Brian
Think of it like this. Grip a peice of pipe gently in your hand and spin it. Then grasp it firmly and spin it again. The resistance to spin it is greater. Same principle for each and every bearing surface in your engine
imagine pushing air through a pipe , then change to water , then change to tar  it takes a lot more power to push tar through the same hole than water or air
resq302
ok, I understand now.  I could imagine if I were trying to get every single ounce of horse power out of my engine for racing and such but right now I would rather have more pressure knowing that oil is certainly getting up to every part of my engine that needs it and sacrifice a couple hp here and there.
Brian
Fred
Quote from: resq302 on June 30, 2012, 06:47:06 PM
:iagree:
