Steering column problem
Started by randy73, June 10, 2012, 07:04:44 PM
randy73
I rebuild my column and replaced the gear box, now the column is 4 1/2" from the gear box. I checked the old gearbox against the new one and they were identical.
what did I do wrong?
73 charger w/power steering.
the inner shaft in the engine compartment that connects to the steering box has probably slid up inside the outer column shaft
Bryan
Patronus
That may be the case, although Im not sure on a 3rd gen. If so, isnt that non-repairable?
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
nothing to repair...it's a collapsible column
Bryan
randy73
Do I have to take the column apart to pull the steering column back out?
no....just pull the center section back down from the engine compartment
Bryan
Patronus
Quote from: A383Wing on June 10, 2012, 09:32:22 PM
Bryan
Once its collapsed I believe the plastic rivets are sheared off allowing the bottom sleeve to turn independently?
'08 CRF 450r
'12.5 450SX FE
no...the plastic rivets are there just to stop the noise rattle in the columns....they are a rectangle shape or a "D" shape..it cannot turn inside itself
Bryan
randy73
I tried pulling it out and it would not budge.
try clamping vice grips on it & tap it out with a hammer
randy73
randy73
Where are the shear pins on the column?
1/2 way up inside the column
randy73
I tried banging it out, but it will not budge.
Where can I get a new column?
Patronus
I hear ya bro. I went through the same thing. When I finally got another column (from a member here in the for sale section) I ripped apart the old one. The rivets are connected by rectangular pieces of plastic as well. One of those fell out and got stuck in between the two sleeves, locking it up. You'll find one, look around. Be careful of ebay, some dudes bait and switch.. Dont ask me how I know.
'08 CRF 450r
'12.5 450SX FE
randy73
Took some serious banging, but I got the column back out.
Thanks for everyone's help!!!    :2thumbs:
Violence always works best, swearing is a close second!   :2thumbs:
Patronus
'08 CRF 450r
'12.5 450SX FE
