Valve adjustment
Started by ugly2u, June 02, 2012, 05:54:23 PM
ugly2u
I did a valve adjustment on my 1000 mile 490 stroker, but it didn't seem right. Harland Sharp roller, lunati hydraulic, edelbrock heads. The motor started making clicking noise, after having gremlin event a few weeks ago (see my other post titled "gremlins?" in this forum)
I used the adjustment sequence on the sticker. Several of the valves were way off; there are now more than 2 threads showing on the adjuster. The motor has not been run in several weeks. I'm concerned that I over tightened the adjuster, and don't want to cause other damage. Could the valves be that far off and making only a little noise? Could the lifters be depressurized, needing excessive adjustment?
Am I supposed to run the engine to pressurize lifters before doing an adjustment?
It can be tricky to get the adjustment right with hyd lifters , you need to be at TDC or set the intake as the exhaust starts to move & the exhaust when the intake closes , you want to back the rocker off until you feel vertical play & then tighten until there is not play & tighten the adjuster approx 1 full turn more , take you time & work through the sequence , if they are adjusted too tight the valve may not fully close
Challenger340
Only wimps wear Bowties !
ugly2u
Lifters are crane 99378-16.
So, if the valves lash is too tight, the valves won't seat. But will it bend or damage anything? Possibly over compress springs, I guess.
ugly2u
I went back and loosened the rocker adjustments. Gonna warm the engine and start from the beginning.
:eek2:
