no dash lights
Started by 68 R/T blue, May 20, 2012, 07:01:07 PM
68 R/T blue
I have a 68 charger 440 the fuse box had been replaced I can't get dash lights to work everything else works. I have looked at wiring diagrams and not sure where the power is suppose to come from. HELP!
jaak
A bad dimmer switch (dimmer wheel) will cause the dash lights to not work. Here is a diagram I drew up a while back ago showing how to bypass the switch. All you need is (3) Male blade terminals, (1) Female blade terminal, and a couple short pieces of wire. Do this and see if your dash lights work. If it works you can run it like this until you replace the switch, but dash lights will stay at the brightest setting, dimmer wheel won't work.
Jason
68 R/T blue
thanks for the info turns out the dimmer is bad. So for know I bypassed it.
