Speedo cable routing
Started by bull, May 16, 2012, 10:22:00 PM
bull
Just go my new speedometer cable and ran it from the trans up to the dash but I have a couple of routing questions. First, does the cable go straight out from the trans to the frame rail and then forward? If so, does it go above or below the torsion bar? Next, where does the clip go? There's a lip in the sheet metal that runs about 10 inches back from the firewall on that side which is where I have it now. Seems to be the right spot but I'm not sure. Last, once the cable come through the firewall, does it go between the clutch and brake pedal up to the speedo or does it go to one side or the other? And is there a other place under the dash to secure the cable or is it loose at that point?
Dans 68
bull
Oh, you guys are a big friggin' help.
Fred
17000+ posts................haven't you learnt anything?   :smilielol: :smilielol:
It goes straight through the firewall. The hole should be provided (factory standard) under the master cylinder. The cable goes over the torsion bars. The clip is fine where it's at. The cable hangs free from firewall to speedo.
bull
Quote from: Fred on May 17, 2012, 12:49:16 AM
So between the brake/clutch pedals or to one side? Or are you one of those two-pedal pansies? :nana:
Fred
Quote from: bull on May 17, 2012, 12:55:48 AM
Make a bee (straight) line from the hole in the firewall to the speedo connection. (do not turn left or right :lol:)
bull
Unless there's a pedal in the way, right? Not sure I want the cable rubbing on one of the pedals.
Fred
Quote from: bull on May 17, 2012, 01:28:26 AM
Gee Bull I didn't have that problem. My cable clears the pedal nicely. If that's the case, maybe you could use a cable tie.
If all else fails, drop the car off at my place and I'll fix it for you.
Pedal pansies obviously don't have that problem............that's what you get when you have one pedal too many.  :nana:
bull
Sure, you can finish it all for me if you want. :2thumbs:
I'll try to snap a pic of mine while I'm at the garage today. I do not have any detail pics of those areas yet so I need some for the collection any way.
bull
Wouldn't you know it - that car is missing the speedometer cable...
I guess whenever you figure it out I'll need to know as well.
bull
Quote from: Troy on May 20, 2012, 09:54:01 AM
:lol: Oh well. Right now I've got mine going between the pedals but I won't really know if that's going to work until I get the gauge cluster installed. Found one picture that showed the cable going just to the left of the hump in the dash frame for the steering column. If that's right it would seem the most direct route would be between the pedals. Either way I think I'm going to try anchoring it it somewhere/somehow.
Yep, it pretty much only goes one way. It's super stiff so you can't really bend it around anything and still get it attached to the speedometer.
bull
Yea, without having installed my cluster yet I was going by a pic I took of the empty dash frame before I pulled the drivetrain. Of course I didn't take a picture from under the dash. :slap: There are lots of pictures I wish I would have taken during the disassembly process.
Dans 68
Curtis,
my speedometer cable routes between the pedals and up to the speedo, with no cables or ties.
Dan
as does mine...but I'm not getting down there to take a pic...I'll never get back up
Bryan
jaak
Dan,
Is the spring on running from the brake pedal then hooked to the column a factory spring...or did you add it?
Jason
Betting he added it to keep his brake lights from staying on...it ain't factory
Bryan
Dans 68
I purchased the car with it.  ;)
Dan
bull
Quote from: Dans 68 on May 20, 2012, 01:56:33 PM
Curtis,
Dan
Gah! Something about that thing rubbing against the clutch pedal really bugs me.
bull
I wish I had about 10 more pictures of your underdash, including (but not limited to) the map light and ash tray wiring.
Dans 68
Quote from: bull on May 20, 2012, 06:19:30 PM
Curtis,
Dan
Yeah, probably only good for a 100,00 miles or so....  ;)  It looks fine to me.  :Twocents:
Quote from: bull on May 20, 2012, 06:24:16 PM
That probably could be done. I'll post them here when I get a few snapped. May not be the best detail, of course.
Dan
gtx6970
Comes out of the trans then goes over and thru a clip thats spot welded to the floorpan , then turns and goes forwad along the frame rail
best one I got
As far as under dash  I don't think there is or was any kind of routing clip on a B-body
bull
Quote from: gtx6970 on May 21, 2012, 08:40:55 AM
best one I got
Great pic. :2thumbs: Do you sell these both as a kit and individually? What kind of screws are used to fasten those two to the inner fender? Nevermind, I found it on your site. I'll probably be getting that one from you soon. Are those pieces plated or bare steel?
HeavyFuel
here's one of the map light.
HeavyFuel
sorry for the size....kinda big....and just over all random-ness.  I've got a ton of pics of my car during dis-assy.
HeavyFuel
more
HeavyFuel
more
HeavyFuel
still more
HeavyFuel
more still
HeavyFuel
ok this is it.
bull
Wow, thanks. :2thumbs: So what do the other two ends of that harness plug into? My harness is pictured below and there's the three spade plug with two yellows and a pink, and then the single spade plug with a yellow tracer wire. Those ends are what I can't figure out but I'm leaning toward time-delay relay on the big plug. No idea yet on the other unless it's part of the door switch deal.
yea...the 3 prong plug is for the time delay thingy
Bryan
HeavyFuel
I took another look for a pic of where that harness might connect to....of course....I'm not finding it.  :shruggy:  I have hundred of pics, but it seem like that all important one never gets taken. :-\
I ca go and look at my dash (on the workbench) and see if I can figure things out.   It might be a few days from now.
Here is the speedo cable from under.
bull
Quote from: A383Wing on May 22, 2012, 10:18:35 PM
Bryan
Yea, it has to be but why do the 68 schematics only show two wires going to it? :shruggy: :brickwall:
Quote from: HeavyFuel on May 22, 2012, 11:07:55 PM
Thanks. Much appreciated. :2thumbs:
bull
And I think I figured out the lone yellow wire. Looks like it goes to the ignition switch courtesy light plug (which is busted).
