Water Pump
Started by WhiteOnGreen, May 15, 2012, 12:41:32 PM
WhiteOnGreen
Last weekend has been a disaster, water pump fail and fan broke the radiator :brickwall:
Today pull the water pump, it´s a new Milodon but the bearing colapsed  leaving the shaft without supports.
When I was checking the pump, I have noticed that in the casting read GMB japan.
I know GMB is a North America Company but, do they make for Milodon? :scratchchin: I bought in Summit Milodon water pump :shruggy:
 :brickwall:  oh noo , sorry to see this  , thats a bummer  :icon_smile_blackeye:
i have the same pump  from Milodon , had GMB japan cast into it ( i ground  it off before i painted it orange)) , got it from mancini 3 years -ish ago  :yesnod:
:popcrn:
resq302
perfect timing.  I was just thinking that of all the spare replacement parts I have, I don't have a water pump on hand and was about to order one in the next day or so.  Looks like I will just get one of the standard cast iron housing ones from an over the counter parts store.
Brian
RallyeMike
(edit) Never mind.....
BUMMER!
1969 Charger 500 #232008
1972 Charger, Grand Sport #41
1973 Charger "T/A"
Musicman
Brightyellow69rtse
i ran the milodon pump that had the gmb cast into it for prolly 10 years. it was still fine but i just replaced it when i changed to the aluminum housing. i wouldnt hesitate running another one.
Rolling_Thunder
I've never had a water pump fail...    but damn that sucks.
looks like maybe fan is to close to radiator..also looks like fan clutch is a bit long
Bryan
WhiteOnGreen
 :cheers:, Is time for choose a new fan and clutch fan, loking in thr forum and a lot of people install a Hayden Jaguar clutch fan, but for the choice fan I like the factory look and I saw 5, 6, 7 blades fan. Which is better? Engine is a 383 HP A/C
About clutch, termal or mechanic?
Quote from: WhiteOnGreen on May 16, 2012, 01:50:59 PM
The one that moves most air so look for cfm.
ChgrSteve67
I have a few 7 blade fans, one recently powder coated and two good fan clutches, one short shaft and one long shaft (I think one of them is even brand new).
I don't know the fan size off hand.
PM me if your interested.
-Steve
I'm running non-thermal fans on all my cars...those move more air at lower rpm's than a thermal style
Bryan
