Thermoquad help
Started by moparguy01, April 30, 2012, 08:43:45 PM
moparguy01
So i have a thermoquad on my 78 chrysler new yorker. ANNNND leanburn. it works alright, and at the moment I just don't have the funding to swap carbs and do the lean burn exorcism. The problem is the secondaries do not open. I pulled the carb off, and about 1/3 of the time I go through the throttle the secondaries will open. Otherwise they dont even twitch. I'm guessing its a linkage issue, but cannot for the life of me see where the issue is. Does anybody have any insight for me on taking care of this?
also:
http://www.imperialclub.com/Repair/Lit/Master/290/index.htm
NEEDS TO TAKE CARE OF THE LEVER what makes it work:
but needs to be adjusted in order. I simply jumped directly to the points to check
