what type of paint?
Started by coxie1996, April 09, 2012, 08:26:16 PM
coxie1996
soo im almost to the point of painting my engine bay, blasting almost done.  i have a nice spray gun, just need to know what paint to use? going with satin black with semi gloss clear.. please help either this or spray can it lol  :brickwall: thanks!
twodko
Why black for the engine bay? Is the car black? Were it me, body color for the engine bay.  :Twocents:
AirborneSilva
Quote from: twodko on April 11, 2012, 10:59:48 AM
That's the way Maw MOPAR did it from the factory  :2thumbs:
coxie1996
i knew id be getting crap for saying black  :lol: yes the front is black(hood, and stripes on both fenders lol black will go with it nicely.. just need help! i have nobody to turn to help me with this except this thread.. ive never did this before  :shruggy:
lukedukem
1969 Charger XP29F9B226768
1981 CJ7 I6 258ci
2016 F150, 5.0, FX4, CC
bill440rt
If you are on a budget & "just" doing the engine compartment, might I suggest a single stage paint in this situation.
Want to do it really cheap? Go down to Home Depot & get a quart of Rustoleum semi-gloss black in a can, thin it a little with paint thinner, & have at it. About $20 bucks.
From what I understand John Deere's "Blitz Black" is similar, found at most tractor supply stores. Might be a little more expensive. These paints don't have the best UV protection, however it's underhood & will not be exposed much to sunlight.
Or, if you want to do it a little better, Eastwood has some Rat Rod black reasonably priced that comes with the necessary hardener & reducer. Most of what they sell is re-labelled name brand stuff. Check out their website. Around $100 or so?  :scratchchin:
If you want higher quality still, look into SEM's Hot Rod Black & DuPont also offers a similar single stage flat/semi-gloss black. Go down to your local auto body supply store & speak to one of their reps.  :yesnod:
For ultimate durability (& expense), then base/clear. If this is your first time with a spray gun, then this is not the way to practice. Unless, you have a high budget & are willing to do it twice.
Doing a small area such as an engine compartment might be a better candidate for single stage, especially if you are unsure what you're going to do with the outside of the car at this point.
Good luck!  :2thumbs:
