Pypes X-pipe?
Started by SRT-440, February 24, 2012, 03:14:17 PM
SRT-440
Is this the one I should run on my 70 RR? Fitment issues? I do have headers (not sure the make of them tho..3' collector)
http://www.summitracing.com/parts/PYE-XVA13/
I Looked at the TTi X-pipe but it's $100 more.
Plan is to run an xpipe off the headers into ultra flo mufflers with turn downs. I don't have a drive shaft loop to worry about...tho I prolly need one running drag radials.  :scratchchin:
"It's not the size of the dog in the fight, it's the size of the fight in the dog..."
2012 SRT8 392 Challenger (SOLD)
2004 Dodge Stage 1 SRT-4 (SOLD)
1970 Plymouth Road Runner Clone w/6.1 HEMI (SOLD)
1971 Dodge Dart w/440 (SOLD)
1985 Buick Grand National w/'87 swap and big turbo (SOLD)
GreenMachine
I used the Pypes header back exhaust kit on my Dart. First of all, from what I've read there are 2 grades of stainless steel and I'm sure they use the cheaper grade. Second, the 2 pipes after the X were too close together so I had to use a floor jack in between the 2 to spread them apart. For what you need, they'd work fine, but if you can find cheaper, I'm sure the quality couldn't be any less.
471_Magnum
I purchased their 2.5" header back SS kit. It sucked and I returned it.
It appears the B-body X-pipe is the same as the one they use on E-bodies. To get the length required, you end up with the front spacing way too wide. It would have taken a lot of modification to get the kit to fit to my satisfaction.That additional cost is better spent on a much better fitting TTi kit. There were other concerns/issues as well.
billschroeder5842
Also consider 3" pipes...totally worth the effort. Go on You Tube and listen to the difference versse 2.5 pipes.
Texas Proud!
redmist
I did 3" from the 3.5" Collector, to an X, to dumps right in front of the rear axle. Two dynomax muffs between it all. The sound is devastating!!   :drool5:
JUNKTRAVELER: all I've seen in this thread is a bunch of bullies and 3 guys that actually give a crap.
SRT-440
Thanks for the responses...I'm def gonna go with 3 inch TTi Xpipe with ultra-flos.
strokie
I just finished installation of 3.000 inches X pipe on the Charger 67... :icon_smile_big:
It's really a perfect fit.
You know why...
It's TTI
:Twocents:
SRT-440
Do u have TTi headers? I'm wondering how well it will work with other headers.
471_Magnum
Quote from: SRT-440 on February 26, 2012, 12:02:16 PM
Looks like he's running manifolds or shorties.
The TTi pipe should adjust to just about any header, but ground clearance might be impacted. They offer some collector adapter options.
SRT-440
I've got crappy flowmasters with turn downs now...WAAAAYYYY too loud and sounds like crap.  :rotz:
I'm really considering just going all the way to the bumper this time and hoping that helps with cabin noise and exhaust smell.  :shruggy:
Lunger
i'm gonna go with a mix but going to use this x pipe
BULL OF THE WOODS
Surf Charger
Quote from: strokie on February 26, 2012, 08:50:57 AM
You know why...
It's TTI
:Twocents:
I have to agree with you on this. After much debate, I sucked it up and bought a set of thermal coated TTI headers. Not cheap at all...double the price of some stuff out there....however they did fit perfect. I didn't have to hardly move anything to get them installed.
