MSD question
Started by Mr. Lee, February 12, 2012, 01:53:35 PM
Mr. Lee
I own a 69 Charger with a 440. I want to replace the stock ignition for a MSD ignition in the near future.
I looked on the MSD website and came up with this:
http://www.msdperformance.com/product.aspx?id=16013
http://www.msdperformance.com/product.aspx?id=5665
http://www.msdperformance.com/product.aspx?id=6285
http://www.msdperformance.com/product.aspx?id=5003
What do you guys think yourself what to take? Thanks.
Serge
AirborneSilva
I've heard the distributor can have clearance issues (think it was in reference to a high rise manifold), otherwise I like the rest.  :Twocents:
skip68
I bought the same setup and it's perfect.   The only issue I remember is valve cover clearance depending on what type of valve covers you have.
AirborneSilva
Quote from: skip68 on February 13, 2012, 10:17:12 AMThe only issue I remember is valve cover clearance depending on what type of valve covers you have.
Yeah, now that sounds more like it... Thought I remembered something had clearance issues  :icon_smile_big:
Cooter
Get yourself a reman Factory electronic distributor and run the MSD with it..Boom, no more issues. Works great.
Mr. Lee
So the 4 items together is "plug and play" and just works fine together?
Also, this is what my engine looks like. Will it fit with the valve covers?
Thanks for the input  :2thumbs:
mhinders
Quote from: Mr. Lee on February 12, 2012, 01:53:35 PM
Serge
It's funny to read the descriptions of their products, they are really innovative with words "increased power with less current", "up to 135mJ spark energy" (yes, maybe at idle, but at 6k rpm???).
Compare the specs of the MSD Blaster 2 coil with the corresponding FlameThrower III from Pertronics. The FlameThrower III coil leaves the Blaster 2 in the dust.
It's not easy to cut thru the marketing fog if you want something really good...
Martin
Dodge Charger 1967, 512 cui, E85, MegaSquirt MS3X sequential ignition and injection
I like MSD stuff but there are better options for the ignition wires. The QC is not what it used to be  :P
skip68
Yes, it's easy to hook up and yes it will fit with your valve covers.   I had the same covers.     :cheers:
mhinders
Quote from: firefighter3931 on February 14, 2012, 07:59:55 AM
No doubt their products are good, but what annoys me is that it is not possible to do a desktop comparison of the different products and vendors, simply because they don't publish all data that is needed. They give glimpses into one or the other good parameter, while the rest remains a black box. Like 135 mJ spark energy, but at what rpm?? I bet at idle, becuse that is where you get maximum, the higher the revs the less energy to the spark plugs. And the text "increased power with less current" may be true in one limited section of the system (by stepping up the voltage), but it's basically BS looking at the whole system. Increased power somewhere in a 12-14V system has to come from increased current, unless there is a small nuclear reactor hidden in the box.
Well, maybe I shouldn't pay attention to the marketing text and try to focus on getting the technical parameters, but "clever" marketing can really get me going... ;D
Martin
