Ignition lock bezel
Started by bobfist, November 15, 2011, 01:30:44 PM
bobfist
Hi!
I wonder if its possible to install the ignition bezel on my 69 after the dash pad around it are installed?
www.bobfist.com
Muscle Car Restorations & Reproduction
Sweden
It should be - I've taken them out without removing the pads.
Chatt69chgr
I took mine out with the pad on by carefully using long nose pliers to engage the slots.  It was not tight.  There is a tool made to install/remove the bezel.  Kind of pricy.  Might be necessary if the bezel wouldn't move.  O/W, you may end up ruining the bezel.
bobfist
www.bobfist.com
Sweden
