Tire size ?
Started by RGA, October 22, 2011, 10:51:55 PM
RGA
I just picked up a set of cragar SS rims today. Should look great on the 69. What tire size fits the best on the front ? They are 15 inch by 7s in the front and 15 by 8's in the rear. I already have the rear tires but can't decide what size fits the front the best. What did you guys use ?
UFO
I've got the same size rims.
Using 275/60 & 225/70.
RGA
Thanks, just found the thread on this sight dedicated to tire size. :2thumbs:
bakerhillpins
I put bigger tires (diameter) on the front and it's not horrible but not my favorite either. I think the front has too much sidewall.
235/70-15s up front and 275/60-15s in the rear.
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
triple_green
235 60 15 front fatter looking than the 70 series.
68 Charger 383 HP grandma car (the orignal 3X)
terrible one
Quote from: triple_green on October 24, 2011, 09:42:21 PM
I'm also using this size up front with a 7" wide rim. :yesnod:
235 wide is 235 wide the 70-60-50 makes them shorter , the sidewall is 70% of the width , or 50% of the width
Budnicks
There is a great tool sold by "Percey" for like $70, from Summit Racing & others I'm sure, it will give you exact sizes, tires, back spacing & diameters of wheels etc... It's a great tool if your looking to get the most out of tire fitment, especially if you plan on filling the wheel wells a much as possible " with out, any rubbing or fitment issues "...  I use BFG TA's 245/60/15 on 15x7's w/3.25" back spacing up front & BFG TA's 295/50/15 on 15x9.5's w/4.5" back spacing in the rear, fit perfect never any issues could go larger with the right tire & rim combo....
 :iagree:  yep perceys wheel rite !!  got one/had one   a few years back  ,
its hours of fun  ,  don't forget to check all four corners   :Twocents:
mysil bergsprekken
Quote from: Budnicks on October 26, 2011, 09:41:47 PM
"BFG TA's 245/60/15 on 15x7's w/3.25" back spacing up front". Do you still have that fender stiffener thingy in the inside of the fender still, or have you bendt it in for clearance?
69 charger RT
Budnicks
Quote from: mysil bergsprekken on October 27, 2011, 11:26:07 PM
My car I have now is a 68 RR, but have used the same set up on my 68 Charger also with out removing or bending anything... The 68 Charger may have been 15x6's with 245/60/15's up front. it was a few years ago now, but no were near any rubbing issues, any were, at a stock ride height, if it was lowered a couple of inches it may become an issue...  That's why I recommended the "Percy tire fitment tool" it leaves nothing to chance, "I think if it was even the 245/60/15's on 7" wheels it would still be ok"
mysil bergsprekken
"I think if it was even the 245/60/15's on 7" wheels it would still be ok" <--Yep I think so too.
but I think I will get the percy wheelrite thing to check all clearances first before I get new tires and rims.
I am thinking of the setup with the: Hoosier Racing Tire Pro Street, LT 26.5 x 10.5R15 up front. I believe this might be pushing it, since they (according to a tire calc online) is the same as an Actual size of    267/57 R15.
And I want to put it an an 7 or 8 inch rim.
What do you think???
69 charger RT
Budnicks
Get the tool it's cheap insurance... Less returned goods... these cars have a ton of room in the wheel wells...
