lokar setup
Started by AmadeusCharger500, January 17, 2006, 01:39:32 PM
AmadeusCharger500
What do I need to change my trans throttle pressure to a lokar unit. Their websight is not very informative.
Do I need to change the throttle cable, intake mounted bracket and carb bracket?
This is for a 383.
1970440RT
      When I did mine, I used the same throttle cable but had to fabricate a bracket to attach the lokar kickdown cable to the intake.  The throttle cable bracket and carb bracket remained the same.  By the way, Lokar's directions that come with the cable are worse than on the website.  Someone on here ordered a kickdown cable from Bouchillon Performance and said the instructions were much better.  I've ordered stuff from Bouchillon before and got great service and product, so the next time I'll order the cable from them even if it costs more.
AmadeusCharger500
Well thanks. I think that about did it. I went to their sight and they even have the directions online. I think I will get the kit from them also..
HH
