727 trans
Started by coach, August 19, 2011, 01:18:36 PM
coach
quick question. I have a 727 tranny that has been rebuilt. Numbers are PK3515846  A-727-B  and 433-3. transmission was in a 69 charger which originally came with a 318. however, i believe that this transmission is out of a 1971 dodge. It was mounted behind a 383 that has since been trashed. I need to know how to identify if this is a big block or small black transmission.
oestermarken
If it was mounted on a 383, I think there is a good chance it's a big block trans.  :scope: :thumbs:
Maybe I don't understand the question :scratchchin:
/Brian
69 383 4bbl
White Hat Special
Light Bronze Metallic
coach
I would have thought is was a small block since it is stamped A-727-B. but that is the questions how else can I tell if it is a Big Block or Small Block.
gtx6970
1970-72 727 from a 383 or 400
oestermarken
Quote from: coach on August 19, 2011, 01:38:34 PM
Torqueflite bellhousings and bolt patterns are specific to each engine family. Slant 6 Torqueflites will only bolt to slant 6 engines, small block Torqueflites will only bolt to small blocks, and big block Torqueflites will only bolt to big blocks.
Although big block 727s and small block 727s to not interchange between engine families, the internal parts do interchange.
/Brian
69 383 4bbl
White Hat Special
flyinlow
If you look at the trans. from the front with 12:00 being up. A bigblock trans has the starter at the 3:00 position, the smallblock has the starter at the 4:00 position......And of course it's always 5:00 somewhere!
PK3515846 is from a '71 383-4 or '72 400-4.
