15x7 or 15x8
Started by Just 6T9 CHGR, August 17, 2011, 07:10:07 PM
Getting ready to buy my set of repro steel wheels and am not sure what size would look better with my tires.
I will be using 255/60/15's on all 4 corners. They are radial redline tires.
Currently I have them on 15x7's and they are fine. 255's call for a 7-9" rim width.
If I got the 15x8, I think it would make the tires more "squared" on the sidewall instead of balloning out.....but
with the 15x8 it would make the dog dish caps appear "deeper" in the rim no?
Looking at this pic of my other wheels you can see the 295's in the rear bulge on the sidewall where the 245's in the front are flatter...
Which would be the better look?
Opinions welcome   :cheers:
charger Downunder
I like the bulge look i run 15 by 8 all round 295 50 rear and 245 60 front. Plus if you clip the kerb you save marking the rim.
[/quote]
Charger-Bodie
I like 15x7 better. You get too much rimm look with 8s. Hard to see the center then,unless you look straight on.
Quote from: 1HotDaytona on August 17, 2011, 07:31:40 PM
Thats along the lines of what I was thinking myself :scratchchin:
UFO
How much rim will depend on offset.
Sure it's a inch wider,but the reality is about 1/2 to 3/4 inch is all you see at the front.
bull
Not me. I like the squared off look myself so I would go with 8s.
This is a pic from Moparts of a RR with 15x8....I dont think I like the deepness of the rim.
This is a 15x7 (or 15x6) on this '69 (member baboyzn (sp?))
What to do what to do???  :rotz:
1BAD68
these are 15x6's
very wimpy looking
just from the point of view of the tire alone having a rim in the middle of the accepted range would be better for the tires , beter footprint , more even wear etc , I would go 8s
twodko
We put 235 60 15's on 15x7's for the front and 275 60 15's on 15x8's on the rear of our 69 and they look balanced and aggressive.  :Twocents:
GPULLER
I prefer the flatter sidewall.  My 295's are on a 10" rim, and they have the same sidewall profile as the fronts which are 235's on 15x7's.  If they balloon out it looks to me they are on too narrow of a wheel.
bull
Quote from: Just 6T9 CHGR on August 18, 2011, 07:26:17 AM
I bet that has more to do with the offset than the width. A centered 15x8 would probably not look so deep.
WHITE AND RED 69
What's wrong with the wheels that you have on it now?  :shruggy:  But if you are changing them go with the 8" wide.
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
255 -60 -15 on a 8 inch wheel with 4 inch back space  all round  , went with 4 inch !  gave it the deep dish look was after  :yesnod: ( only picture i have of a close upish front wheel /tire shot  on computer)
now thinking painting body color as i have since got red line hub  caps
http://www.dodgecharger.com/forum/index.php/topic,74591.0.html      but  think the black steel wheels look mean  :yesnod: so jury is still out   :scratchchin:  might even take the hubcaps back off  :scratchchin:
took this earlier  , while i was taking pictures for the vacuum line thread  :yesnod:
thats how far the hubcaps are in with a 8 inch wheel & 4 inch back space
Thanks for the shots Steve....not home at the moment to check them out on my big screen... Will check em soon!
Quote from: Just 6T9 CHGR on August 20, 2011, 07:49:00 PM
no probs   :2thumbs:    , let me know if you need anymore pictures  :yesnod:  :2thumbs:
Charger RT
bill440rt
Chris, if you plan on running the same size tire all the way around I like the 15x7 look myself. It sounds like you want to keep an original look with these steelies & dogdishes.
:Twocents:
Budnicks
Maybe go with a wider deeper back spacing, you can have the best of both world the wider rim, for the squared side walls look & the shallow look of the std style wheel    :drool5:   most wouldn't even notice it unless your really looking for it...  :Twocents:
Thanks to all that replied!   I placed my order this AM with Summit Racing for a set of 4 15x7's....I wanted to keep a "stockish" look with these steel wheels.  For the non stock look Ill switch to my Cragars ;)
twodko
I'm looking forward to seeing them mounted up. Good on you!
yeap... on steelies I think 7" are better "stock" look than bigger... any other ( but rallyes ) 8" is better options.
Rallyes also in 7" because bigger makes the trim to look weird, and reflection of inner cutouts doesn't make the full circle effect over trim.
