Ignition Power
Started by koshe, July 08, 2011, 09:15:52 PM
koshe
I have a 68 charger with a built 318. For some reason I have no power going to my ignition switch. I have power to the starter relay, alternator and headlights. Nothing to the coil or ignition switch. All factory stuff and in good shape. The harness connections at the firewall appear to be tight with no corrosion to be found. Any ideas??
I removed and rebuilt the motor over the winter and just installed it. I am stumped!!
The blue wire going from that starter relay to the junction block is good. Fuseable link is good.
koshe
ignition wire came out of my starter switch. This repair is going to suck. NO room to work. Need to take the cluster out....I need to figure out just how to get it out.
