Back glass
Started by JT01, July 04, 2011, 08:39:33 AM
JT01
Not sure if this is the right place for this but Im getting ready to put the back glass in my 69 Charger and a friend of mine he also has a 69 charger said to find out what size tape to use (how wide)that the glass will sit on and to find out what size rubber shim I need to put in. Thanks for any help.
jaak
Buy the 3M 5/16 round butyl tape (can't remember the part #). It comes with the rubber blocks.
I started by sitting the rubber blocks in place, then the glass (without the butyl tape). Center the glass into the opening, then placed a couple of strips of masking tape at top, bottom and sides for a guide. Took glass back out, installed butyl on pinch weld, set glass back in placed and pressed down firmly along perimeter of glass. Installed trim. Simple job, took me (with wife's help) about 30-45 minutes. Also another tip, get a couple of those suction cup handles, to aid in sitting the glass in.
Good luck,
Jason
JT01
Thanks for the info Jason.  :2thumbs:
JT01
Do you know any websites that sell it I stoped by 2 local auto glass places and they dont keep anything in stock they both order as they need it. They both said the best place would be online. thanks
Rolling_Thunder
I got mine off ebay...        i used the same 5/16" round stuff...     I got my window in in about 30 minutes by myself...    I also got some of the primer that can be used with it.    :2thumbs:
jaak
Its 3M part number 08611. Here it is on a website, but any parts house should be able to order it for you if they don't have it in stock.
http://www.repaintsupply.com/cat_auto_glass.cfm
Jason
JT01
Just found some on ebay under that part number Thanks alot guys
