rusty rotors
Started by 69pistolgripRT, January 10, 2006, 10:18:16 PM
69pistolgripRT
I have some brand new rotors that were stored outside for some time before I got them. They look fantastic but have very light surface rust.  Do they need turned or does someone have a home remedy for cleaning them up?
1969 RT 440 Pistol Grip 4-speed
Savannah, Ga
there are a few ways to deal with this , if the rust is light you can use steel wool , emery cloth or fine sandpaper to remove the rust Or just install them & the pads will quickly remove the rust
d72hemi
 :iagree:
You could also crumple up a small piece of aluminum foil, and rub it. You will be amazed at how well a ball of aluminum foil will literally erase a little bit of rust.
Ian
