Help with Speedo *VID*
Started by chargd72, June 01, 2011, 08:53:37 AM
chargd72
I finally got around to fixing my speedometer.  It hasn't worked since I've had the truck.  Now it just jumps all over the place.
What I've done:
1) Took out the speedometer pinion, cleaned it, made sure it turns freely
2) put in brand new cable with plenty of lube
3) I could easily spin the cable while it was in place with my finger tips so it doesn't feel like it's catching on anything
4) Hooked one end into speedo pinion gear, other in speedometer
And this is what I get...
http://www.youtube.com/watch?v=XEoRTODRZAM
It's in a '76 W200 400/727.  Odometer is turning smoothly.
Any ideas?
69rtse4spd
Just thinking here, could the square drive on the speedometer be worn out, letting the cable bind & then slip. Could the new cable be just under sized enough to do the same thing. If you have a spare speedo around, could pull the cable, hook it to the spare, go for a test drive while someone else watches the speedo.  :Twocents:.
chargd72
Thanks for the suggestions.  The rear drive at the speedometer locks to the cable well and turns freely but maybe testing the cable with a new speedometer is what I need to do.
rt green
carfully hook the cable up to a drill. see if all is well on the top side. might be able to narrow it down
third string oil changer
chargd72
Quote from: rt green on June 02, 2011, 09:40:10 AM
Already tried that.  Speedometer did the same thing, jumped all over the place.  I assumed it was the inconsistancy of my dying drill.  Maybe it's the speedometer.
Rolling_Thunder
possibly the magnet in the speed ?
chargd72
Charger_Fan
I agree.
My bet is on a bad/pinched/worn cable housing...one of those three.
chargd72
Got it fixed. It looks like I was using too heavy of a grease. Cleaned the cable off and put lithium grease on it and it's working great now.
