Fender tag decode-help?
Started by elacruze, May 13, 2011, 11:02:39 PM
elacruze
I never fully decoded the fender tag before, and looking at it I see that what I thought was mechanical damage is actually 3 numbers stamped in the last 3 positions of the top row-very hard to read due to over-striking and age. I believe the first two characters are 2 and 6, the third could be a 1 or 7 (or 4) but runs into the screw hole so it's a crapshoot.
Anybody seen that before?
Looks like UBS/U8 is a light blue metallic racing stripe?!?!!!? I will be somewhat perturbed if I find that to be the case, the tag was supposedly decoded before paint/interior.
1968 505" EFI 4-speed
Alaskan_TA
That looks like an inspectors stamp. To me, it looks like your car was inspected by 861 - whoever that was..........
elacruze
Quote from: Alaskan_TA on May 13, 2011, 11:19:17 PM
Ok, that works.
What about the rest? Blue Racing Stripe? Is that the same as the R/T stripe?
69CoronetRT
Quote from: elacruze on May 13, 2011, 11:02:39 PM
That is a typical inspection stamp from a car built at the St. Louis plant. Very common.
bakerhillpins
Silver car with blue interior and a black top. Interesting colors. Sounds like you are returning it to factory specs? Love to see that when it's done.  :yesnod:
I've never seen that U8 before in UBS but I have also never heard of a XP charger coming from the factory with stripes?
The decoder I use (http://www.jimshine.com/tag%20info/68tagdecode.htm) doesn't really have much info on the UBS. I always thought the U in UBS was the upper door panel color and that has always seemed to match the tags I have decoded.   :shruggy:
What are you decoding with?
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
elacruze
I searched the forum and found an old thread with a link to this online decoder-there are a lot more research resources on that site too.
http://www.mymopar.com/index.php?pid=85
The decoder is a little difficult to use, but I've done it a few times and it always comes up the same.
The car never had any evidence I noticed of any stripes, but when I got it in 1980 the blue interior had been replaced with a '70 black interior so maybe they deleted the stripe at that time. I put a black stripe on because I like it, never considering that it could have had one stock because it's not an original R/T. My girlfriend suggested at the time we make the stripe blue...dammit, she was right and I think it would look rockin'. If it's coded for a blue stripe, eventually I'll change it from black-I want the car to look like it did new, but not act like it.
bakerhillpins
I'm no expert on this but it would take a LOT of convincing/persuasion for me to believe that the car had a factory stripe in any regard as it's a XP car. But then again stranger things have happened.
I'm kinda leaning towards this at the moment: The U in the U position is possibly for a blue color code since I see B in that position for all the cars with Black interior, W for white, etc. The 8 in the B position would typically mean Stripe Delete on an RT car so maybe just a stamping error? Not totally improbable as the car wouldn't have been coded for a stripe on the build sheet. The mistake would have been they stamped the position on an XP car rather than ignored it. I don't have any tag pics from a stripe delete RT car. The 68 RT Troy sold early last year was a stripe delete IIRC. I wonder if he still has a pic of the tag.
[edit] In 68 UU1 is Light Blue Poly, so U as the code for the upper door panel color is logical. Blue interior isn't all that common on 68s. Ive seen quite a few 69s with blue though.
96' VFR750 (Sweet)
elacruze
Since the interior was swapped out, the only chance for a build sheet was the dash and headliner, neither one produced. We'll never know, although I always thought the car was in original paint and there was no evidence of a stripe. If the tag turns out to be a correct code for a blue stripe, I'll have to run it through photoshop after taking some nice photos when finished.
elacruze
Sooo...
Can anybody confirm or absolutely refute this fender tag? I can't find any data on the 'net which says (UBS) 'B'=8 equates to 'bright blue racing stripe' other than the online decoder from mymopar.com.
I talked with Bill and Paul, the car was definitely repainted once.
my books say the "8" under the "B" is for buffed paint...this will be found on silver cars only
you have nothing under the "S"...which means you never had a stripe
elacruze
Quote from: A383Wing on May 15, 2011, 09:47:06 AM
That's what made the most sense to me. I've emailed MyMopar.com to ask what their source of data is-under 'B' they have 8 as a blue stripe, 3 as a Charger Red stripe, 6 as a dark green stripe, 9 as 'special order racing stripe' and the rest 1-0 as 'unknown color racing stripe. This is in addition to the normal codes under 'S' for regular color stripes.
well, I say that MyMopar's info is wrong...or something in the translation got turned around
as stated before, you have no digit under the "S" on your tag....which means there never was a stripe
:iagree: You need something under the 'S' for a stripe. I always thought that silver was the only color that was buffed from the factory - which is the only reason to have anything under the 'B'.
elacruze
So then the colors they list under 'B' are not stripes but are metallic body colors, requiring buffing. That should have been obvious to me.
bakerhillpins
Quote from: Troy on May 15, 2011, 11:23:07 PM
Excellent, learn something new every day! Thanks guys  :2thumbs:  Had that backwards in my notes.. Sorry  :brickwall:
96' VFR750 (Sweet)
