Electric Choke
Started by BubbaDuke, April 08, 2011, 06:18:58 AM
BubbaDuke
Where does the positive side of the electric choke plug into?
Lets Ride....
the positive power wire for the choke ?
  that goes  to a power source  that is powered when the ignition key is on position only , ie  accessory terminal on the back of the  fuse box  , just use a piggy back spade connector ,
some connect it  to the run side of the Ballest resistor  ,  :scratchchin: don't think this is a good idea my self  :Twocents: & would never do this  :Twocents:
Run side of ballast is THE LINE to take the power. On later years in fact, this line gets up to alt brush ( double field alts ) and in the middle, gets a splice to feed the choke control
BubbaDuke
Thank you tan top, and Nacho.
Lets Ride....
