K frame mounting
Started by Paul G, April 01, 2011, 06:12:09 PM
Paul G
Does the K frame have alignment pins to the chassis or does it just bolt up? 1972 B body.
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
bull
K-frame bolts between '64 and '74 have a conical base below the head that lines the frame up pretty well. I don't know if the '72s had any pins or not but I don't believe so.
charger2fast4u
So on a 68 charger you won't have to worry about the k frame not being lined up correctly the bolts will guide it to where it needs to be? Asking this because ill be removing mine this summer and was wondering the same thing how it lines up correctly and not out of whack
Quote from: bull on April 02, 2011, 03:04:57 PM
K-frame bolts between '64 and '74 have a conical base...
well actually must be up to 72s, but 73/74s must be some similar even with isolations :shruggy:
