Blocking heat cross over
Started by twodko, March 30, 2011, 12:14:09 PM
twodko
Hey gang,
Based on my earlier fuel boil off thread what I'm hearing is I need to change the intake manifold gasket using a Felpro 1215(?) to block off the heat cross over. Is this correct? Do I need to change the valley pan as well? I will reuse the stock cast iron intake manifold.
Thanks.
Quote from: twodko on March 30, 2011, 12:14:09 PM
Hey gang,
Thanks.
last intake carb combo i swaped  on mine   , i used one of these  ,
http://chucker54.stores.yahoo.net/felrbenwitbl.html
 depending on what intake you might need to use a gasket/s !    just valley pan with stock cast iron ,  some recommend a gasket with a aluminum intake /head  :shruggy: , i just use silicone sealer with the weiand  stealth 8009 intake  i have on there at the moment no probs
i also used one of these
http://chucker54.stores.yahoo.net/hein4sqboe.html
Hot_Rodder
The 1215 valley pan is what will block the heat cross over off. The gaskets alone wouldn't because they still have the hole provision for one, the tray has a sealed section instead of being open. So yes, you would need to use the tray as well.
