72 Charger Build
Started by chargd72, March 25, 2011, 09:37:23 AM
ACUDANUT
I would ditch that aftermarket floor shifter and find a Factory one..Then down the road you could add a Factory console.  :Twocents:
chargd72
Quote from: ACUDANUT on January 17, 2012, 02:54:36 PM
Thought about it but I'm liking the buddy seat  :2thumbs:
SG1022
Could you take some pictures of the base of the air filter, when it's off? I have my tubing, I just need a filter element that will fit, or can be adapated from a 3 inch tube.
I really want the mopar performance dry filter, over a KN or other oiled element. Problem is, It looks like the elements they sell are made to screw on to a pre existing fitting? Maybe somebody knows where I can get the tube fitting/adapater?
http://www.ebay.com/itm/5-7L-6-1L-HEMI-COLD-AIR-INTAKE-REPLACEMENT-FILTER-MOPAR-/270905404298?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3f13386b8a#ht_1908wt_1139
Look at the picture of the bottom of the filter. It is threaded, and looks FAR bigger than 3 inches.
This one appears to more tapered(and closer to the one you were using). It does not show a picture of the bottom though.
Again, I could use an adapater to go up or down an inch in diameter or so, but the ones posted look HUGe.
SG1022
if yours has that opening, and you can measure the size for me, I can just buy an adapater.  :2thumbs:
71_Charger_R/T
Quote from: chargd72 on March 30, 2011, 08:41:28 AM
Thanks guys, I appreciate all the feedback!
I finished the headlight bezels with the help of CDN72SE.  He sent me the missing screws and tabs I needed.  Thanks Alan  :cheers:   I should have taken a before pic of these.  They were pretty nasty but cleaned up quite well.
you're doing a great job Ryan,  Just one thing..... I know no one will see it with your hide-away grille but you will notice the difference if you drive it in the dark with the high beams on. In the picture the high beam bulbs are in 90 degrees off (sideways) The lenses will cast wrong this way and believe me, I know, you want to see "Bambi" as far down the road as you can when you are caught in the dark. Not trying to be critical.... just want to help preserve all your hard work. :Twocents:
chargd72
Quote from: SG1022 on February 04, 2012, 01:40:14 AM
I'm not sure if that piece comes off or not.  I'll have to check for you.
chargd72
Quote from: 71_Charger_R/T on February 04, 2012, 12:06:48 PM
Good info.  I was thinking about correct orientation when I was putting them together but had no clue which was the right way.  That will save me some time playing around later.  Thanks.
SG1022
Quote from: chargd72 on February 07, 2012, 10:06:58 AM
Thanks man, I appreciate it.
chargd72
Got a few old parts cleaned and painted.  Stop and go power is now installed.
HemiTom
whats up with the SE tail lamp assemblies?? did you leave off the trim??
chargd72
Quote from: HemiTom on March 18, 2012, 08:27:15 PM
Yep, I'm not a huge fan of the trim.  I think it puts too much chrome on the tail.
Stretch
You are doing a nice job. The car looks to be super solid! The floor pans are awesome! Keep up the good work!
I may be schizophrenic but at least I have us!
chargd72
Have a few updates.  I was getting an itch to drive the car for the first time.  After 2.5 years I decided to do what I needed to do just to get the damn thing on the road.  So I wired up the dash, dropped it in and wired the engine bay.
chargd72
Dash in and testing concealed headlight motor.
http://www.youtube.com/watch?v=00cfySIoZSg
chargd72
And finally, the Charger's maiden voyage.  Felt damn good.
http://www.youtube.com/watch?v=PWh5Ieg7RJc
CDN72SE
1972 Charger SE
RIDELIKEHELL
Awesome! Must be a proud pappa  :icon_smile_big:
AMD POSTER BOY
AirborneSilva
Cool, sounds good!  I know it feels good to take it around the block, I take mine for a quick ride from time to time, one of these days I'll have the odds and ends fixed so I can get the damn safety check...  Keep up the good work and keep the pics coming  :2thumbs:
chargd72
No more points distributor and ballast resistor.  Put in a Mallory Unilite dizzy with a Mallory HyFire 6a control box.
bobs66440
Wicked72
cant wait for a stomp on it vid!!!! :cheers:
Foreman72
Eric "Foreman"
Previous: 1972 Dodge Charger
Current: 2002 Volvo S60
"The steps of a man are ordered by the LORD, and He delights in his way. Though he fall, he shall not be utterly cast down; For the LORD upholds him with His hand.
=Psalm 37:23-24=
"But store up for yourselves treasures in heaven..."
=Matthew 6:19-21=
:pat
chargd72
Pepped up the parking lamps this weekend.  Used some resin and hardener to fix the plastics.  Then sanded smooth and repainted.  Now you can hardly notice the damage.  That saved me $160.
nvrbdn
those turned out great. :2thumbs:
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
RIDELIKEHELL
Great work keep the updates coming  :2thumbs:
AMD POSTER BOY
