Dyno day tomorrow!
Started by FLG, March 15, 2011, 07:30:38 PM
FLG
Well guys,
Tomorrows the day my 446 goes on the dyno...to say I'm nervous is an understatement!
Wish me luck, ill be sure to report back with the outcome  :2thumbs:
billssuperbird
greenpigs
What no guess my HP?
I will start anyways, allthough not sure of the build.
475 hp
523 Trq
If it sucks you can allways add more chrome as that's good for 25 HP and stickers in in the window add another 10.
1969 Charger RT
Living Chevy free
Brass
Very exciting - I'm anxious to hear results!
FLG
Thanks guys,
Gp,
I've put most of the stickers on my daily driver for kicks, easily gained a bunch of hp.
Its 440 .030 over heads and block were decked
Kb icon forged pistons .010 in the hole
Engle K56 cam 224@.050 & .504 lift (1.5 RR)
Iron heads with valve job felpro 1009 gasket
Ch4b intake
Proform 750 carb
I'm saying 450hp 520 fl/lbs
greenpigs
Unported heads?
WTH I am feeling generous & will stick with my initial numbers.
1969 Charger RT
Living Chevy free
400/6/PAC
General_01
1971 Dodge Charger Super Bee
496 stroker
4-speed
Long Island RT
1969 Dodge Charger RT Restomod<br />Triple Black, 512 stroker, Tremec TKO600 5-speed<br />2005 Dodge Magnum RT - Brilliant Black - Lowered
FLG
Heres a pic (ignore the painted VC its just temp)
Just got back from work and gotta get to sleep,  4hr ride to MA tomorrow for the big day  :2thumbs:
Very cool.   Interested to see the #'s.  I used the same cam but 915 heads & forged postons
pipeliner
I cant wait to see the numbers either.Just for fun  the motor will have 443 HP and 512 # of torque.
FLG
Well its done...
Didng quite make the numbers but I'm gonna enjoy it none the less
385hp and 470 ft/lbs
Wanted more but eh  :2thumbs:
Sounds about right....maybe better tuning will get you over the 400hp mark....still nothing to sneeze at!  :drive:
FLG
He said if I ditch the hv pump that I don't need and have smaller headers (his were a bit big at 2") ill see 400hp
:2thumbs:
Video tonight
pipeliner
Was hoping for more fer ya but that still aint bad.
greenpigs
I was going to lower my guess, but still that should leave plenty of black marks for you.  :cheers:
We all can't have a 446 like Ron, in fact MOST don't.
1969 Charger RT
Living Chevy free
General_01
496 stroker
4-speed
jb666
Frank -- That's great!!! You should be proud of what you accomplished!! :cheers: :cheers:
Quote from: FLG on March 16, 2011, 04:23:32 PM
:2thumbs:
Video tonight
Those headers are waaaay too large....no doubt that they hurt the output. My old 446 didn't like the big headers either and that was a 500+hp build. A set of 1 3/4 headers would certainly pick up some power. Don't get too caught up in the dyno numbers Frank....every dyno is different. In the real world you have a 415-420HP combo with well over 500ftlbs with the right headers.  :yesnod: You'll see once it's in the car !  :icon_smile_big:
FLG
That's what I figured Ron, good to hear it from ya. I'm going to do a chassis dyno once its done so ill get the right numbers. And I'm sure a few run at the track will tell a real tale assuming it gets decent hook up.
I wanted numbers here but it was more for the fact of working out the kinks, like the oil pump was flawed and we needed to take it apart to fix the internal o ring.
He also said to loose the hv pump as I'm getting 80psi and for what I'm doing I'm just throwing away a few hp by running it.
After breakin he probably did about 12 runs so if the engine was going to fail I'm sure it would have.
Now I can put it in the car and drive it and I need not worry. Well work out the rest of the small tweaks on the chassis dyno.
Btw we had a mishap with #6 wire so I'm gonna need a replacement, just tell me what I owe ya.
No worries Frank, i'll get you another #6 wire  :2thumbs:
I wouldn't worry too much about the oil pressure. Once the engine is at operating temperature driving around on the street those pressures will drop. You allways have the option of using a thinner weight oil so you could use 10/30 instead of 20/50 if the pressures are concerning you.  ;)
The important thing is that the cam is broken in, the rings are seated and you're ready to roll ! Once this motor loosens up it will make more power. Right now it's new and "tight" so with some street mles the power will increase somewhat.  :yesnod: I bet if you redynoed this motor after 1000 miles with the exact same tune it would be 15-20 hp better  :icon_smile_big:
When you get a chance can you scan and post the dyno sheets ?  :scope:
jb666
Now, before I say this, I have to say that I am the FIRST one to be guilty of thinking this way as well...  But...
I get a kick out of "every dyno is different" , and "use a thinner oil". When you get to the point that #'s mean THAT much, what's it all about? With me, I get a # in my head, and if I don't hit it, I go crazy. When my motor was first built, I hit a hair under 600HP. I heard "Oh I could have suggested a different built to get you more power" or "Oh, if you did this you'd have seen 50 more HP". Hell, even the dyno operator told me that I'm losing 30-40HP up high because of the carb I was running, but I did not care about power over 6k RPMS, since my driving patterns will never let me see that range.
My buddy owns a chassis dyno. I do all of his photos/videos for the customers using his facility. 9 out of 10 guys leave there making excuses for their numbers. "it's the machine". "it's his computer". "My car makes 100 more HP, I can feel it, something's wrong!".  My point is that there will ALWAYS be something effecting your results. Take it to the track!!! Then again, wait.. Humidity. Elevation. Track conditions. Oh no, now you're opening up a new can of worms!
I know you had hoped for a LOT more power than you saw, but these #'s are nothing to laugh at, they are damn impressive, and the fact that you did this yourself is even more impressive.  Builders, IMO, are extremely talented people. Ron, Jon, Dennis, and anyone else that does this stuff with their eyes closed have my respect.
I know that, after my last dyno (after the injection and blower were finished) I was told I could get 100-150HP more in a very short time... I said NO.. Time to stop... I was getting carried away with #'s.... And power that I will NEVER use on the street.
greenpigs
I'd say he got what he wanted out of the session & after the chassis dyno he will see what it does in the 1/4.
1969 Charger RT
Living Chevy free
