69 tail light mod
Started by Patronus, March 09, 2011, 11:07:21 AM
Patronus
I've been trying to tackle the tail lights on my '69 for a more bright light. I've tried the LED's (direct 1157/56 swap) and had this chrome tube left over from a skylight install, thought I would share. It cuts with a scissors, and really brightened up the bulbs, looks better than new!!
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
Brock Samson
 :scratchchin: i'm not sure what you did there.. is it mylar that you shaped to fit?..  :shruggy:
Patronus
It was from a tube-style skylight. Made some patterns out of paper, then onto this section of tube we had left over. It was an 8" dia. x like 30" long, laid flat. Cut with scissors, contoured, and held in place with dollops of clear Polyseamseal adhesive caulk. Was just left-overs and easy. WAY better than the silver paint.
'08 CRF 450r
'12.5 450SX FE
Brock Samson
sweet, ok so it wasn't an easy mod. you had to tale the red lens off and contour,.. any decent after pics?..  :shruggy:
   :popcrn:
Patronus
http://cgi.ebay.com/Brand-New-ODL-Tubular-Skylight-Extension-Tube-/150571444991?pt=LH_DefaultDomain_0&hash=item230ec1eaff#ht_762wt_1141
I would take a pic, but its hard to capture, plus have some more tuning work to do.
Thinking about getting some more for front marker lights, one tube would do the whole car.
Leave the protective film on while you work it.
Be sure you get one at least 30" long, 48" would be best so you could do the top and bottom, I had to use chrome spray-paint for that.
'08 CRF 450r
'12.5 450SX FE
I am assuming it will stand up to the heat of the bulbs?
Patronus
Im still in assembly so  :shruggy:
'08 CRF 450r
'12.5 450SX FE
I did basically the same thing to one of my 66's....but I used the chrome metal heating tape that looks like a roll of duct tape...peal & stick...and it will hold up to bulb heat.
Found at most popular hardware stores
