Mopar Purple Shaft
Started by 4speed, March 02, 2011, 09:29:27 PM
4speed
Whats your guys Opinion on the 509 Purple shaft cam in a 440?
1BAD68
nvrbdn
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
The 509 needs some compression and descent intake manifold along with a set of headers to function properly. With an auto trans you need 3800 stall and 3.91 or larger gears. Forget about running a brake booster because this grind makes little manifold vacuum.
There are better cams out there.  :Twocents:
4speed
I have a 440 thats been bored .30. double eyebrow pistons. 915 heads. 10.5 compression. edlebrock torker2 intake. holley 750dp. 3500 stall. and 3.91 gears.
What cam would you suggest? Thanks
billssuperbird
i have it in my 440. and i love it. :2thumbs:
Quote from: 4speed on March 03, 2011, 06:20:53 PM
If i was going to pick a cam for that combo the Comp XE284H would be my choice. It'll fit with no valveguide modifications as long as you have enough valvespring to keep it happy. The Comp #911 valvesprings are perfect and fit with the stock retainers/locks.  :2thumbs:
Make no mistake, this is a choppy sounding cam and won't be mistaken for stock. :apimp: Idles descent with a good ignition curve and makes excellent midrange and top end power.  :icon_smile_big:
The mopar 509 is very close to my cam. I have an old school racer brown 510 cam in my 383 with similar build specs to your engine. I had a 3000 stall converter in it and it was very streetable. Like mentioned above it makes no vaccuum though if you had powerbrakes in mind. But other then that's its a great powerful cam. You can hear mine on youtube. Just look up c00nhunterjoe. I have all kinds of videos of my car
