Hey TUFCAT!
Started by TeeWJay426, February 18, 2011, 01:10:40 PM
TeeWJay426
Just noticed this little tidbit in your sig line:
QuoteSoon to have a very potent "firefighter3931" inspired stock looking 383 under the hood.
Did I miss a thread on this? Come on, spill the beans.... what's cookin' with the Coronet?
74 Charger SE, 400 HP, 4-speed
bakerhillpins
Yea, What up?   :popcrn:
Inquiring minds want to know.  :P
One great wife (Life is good)
96' VFR750 (Sweet)
Capt. Lyme Vol. Fire
TUFCAT
Uh oh... :o  I was hoping to avoid a thread about my engine rebuild so I wouldn't have to post twenty seven eight-by-ten color glossy photographs with circles
and arrows and a paragraph explaining each one....but
Since you guys let the (meow) cat out of the bag, I'll post some details tonight - - I'll even include pictures for those "inquiring minds"!  :2thumbs:
Pictures are for those on here who can't read very well
:D
moparstuart
Quote from: A383Wing on February 18, 2011, 03:21:46 PM
:D
thats me I need the pictures  :2thumbs:  the more the better because i can't read .  short attention span
71ChallengeHer
I already saw it on facebook .  :nana:
mikesbbody
A Picture is worth a Thousand words post them up!  :cheers:
Alaskan_TA
TUFCAT
Sorry guys, I don't have much time tonight, this is all I can give....
The engine design was initially spec'd by Ron (firefighter3931). He made the crucial choices and I didn't devitate from his recommondenations. I wanted to build a very nice "stock" 383 that would surprise a lot of people, and I wasn't interested in building a stroker motor.
I also wanted the best of old-school performance - with modern day tricks using using stock manifolds, and keeping a stock appearance. My Coronet looks like a sleeper so a "stroker 383" wouldn't lend itself to the theme of the car.
My goal with this engine was making it hot as possible, while looking completely stock....which is why I liked Ron's potent .030 over stock appearing 383 recipie. I intitally wanted to use my original 1967 closed chamber heads correct for this engine but many consider the 516 heads to be "low performance heads" I found an unmolested set of "more potent 915 heads" from a 1967 440 HP (w/large valve casting), which I sent to Modern Cylinder Heads for a makeover.
They were machined, ported, and cc'd to 81cc. New bronze guides, hardened valves seats, and 2.08/1.74 stainless steel valves were installed from Mancini Racing, along with Comp cams #911 valve springs and Mancini Racing chrome moly retainers.
MORE TO FOLLOW>>>>>> wait until you hear more about the block.
Bob T
And following this one with Interest  :yesnod:
Old Dog, Old Tricks.
elacruze
1968 505" EFI 4-speed
twodko
TUFCAT
The machine work was done by Denny Hummel at Booth-Aron's http://bootharons.net , but the assembly work as done by Denny's buddy Mike Spinazzola. Mike's had nearly 30 years of experience at Chrysler's engine lab, and a well known for Mopar engine building around Detroit.
Lucky for me, both guys treat every engine like a race engine so it was actually overbuilt ...that's okay!  :yesnod:
The oil pan was pulled and the initial worry set in....tons of metal found.  It was later diagnosed as a "shaved" cam bearings. The bearings were literally curled and cut like an onion ring -  then crushed and ground by the crank.
I was worried about cam bearing replacement since nobody made undersized/oversized cam bearings for this motor. I thought it was going to be a very expensive fix, or a boat anchor.
Luckily, once the bearing remnants were cleaned out and determined that the bearing wear the block...we were on our way!!
MORE TO FOLLOW>>>>>> chosing the right psitons and cam
stripedelete
Quote from: TUFCAT on February 20, 2011, 02:46:58 PM
..........  determined that the bearing wear the block........
Tuffcat , I'm mechanically impaired (but getting much better - thanks to many of you).  What does this mean?
TUFCAT
Quote from: stripedelete on February 20, 2011, 05:25:47 PM
Stripe, engine bearings nothing like typical bearings ...i.e. think roller bearings.
Crankshafts and camshafts rotate within cast "journals" of the block. Typically there's at least five.
Every journal has a pressed bearing that acts like a sleeve. Bearings are designed to be replaceable because the crank and cam rotate on an axis creating sideways load and oblonged wear.
Without replaceable bearings, engine life and repairabilty would be greatly diminished...rendering the block a "throw away" item.
Basically, the engine bearing is a wearable surface that protects the journal.  :2thumbs:
stripedelete
Quote from: TUFCAT on February 20, 2011, 09:31:07 PM
Every journal has a bearing pressed into the block which acts as a sleeve. The bearings are designed to be replaceable since the crank and cam rotate on an axis therefore they always have sideways load causing wear. Without replaceable bearings in a journal, engine life and rebuilabilty would be greatly diminished...basically rendering the block a "throw away" item.
So you determined that the bearing didn't wear through to the block?
TUFCAT
472 R/T SE
Why didn't you want a stroker recipe?
68X426
We Want to Help You.
1958 Dodge Pick Up, 383, loud
1966 Dodge Van, /6, slow
TUFCAT
My impression was that it would to expensive. I also wanted to use stock intake and exhaust manfolds - so it didn't seem logical to build a stroker, then limit its potential.
bakerhillpins
Any more updates? Is the sucker in the car yet?   :popcrn:
96' VFR750 (Sweet)
TUFCAT
Brian, it's still sitting there...untouched.  :'(
I did buy a complete exhaust systenm from Accurate Ltd, and that's the biggest update!
Somehow our major basement remodeling project came in front of my engine project - which one do you think wifey wants done first?.. :scratchchin: :icon_smile_wink:
71ChallengeHer
Quote from: TUFCAT on March 28, 2011, 11:46:48 AM
Poor. Tufkitty.  :pity:
quadram4
OK tuff-one Mike and I r waiting for the eng install, Mike wants to get going on the break-in and I want to hear it run!!! We wikk be there,
Hungry Dago
Hungry Dago
Jake
Quote from: 71ChallengeHer on March 28, 2011, 11:48:42 AM
Misery loves company Tufcat, I ended up giving my wife priority as well this past winter with a Kitchen remodel. Sucked up lots 0 $$$. We can sit around and look at our stalled car projects.  :cheers: :brickwall: :RantExplode: :shruggy: :cheers:
