My 68 R/T
Started by Piston_Freddy, January 04, 2011, 04:09:47 PM
Piston_Freddy
Thanks tan top! Anybody else want to chime in on the balancer issue? OEM or new aftermarket one? What kind a aftermarket one to get? :shruggy:
Max rim size:15"
Piston_Freddy
Just got back from the parts store.They can't order from Summit and Rockauto hasent' listed any balancers. I think the only way is if someone orders a balancer and then sends it to me? I was planing on buying this one: http://www.summitracing.com/parts/SUM-163383/
Max rim size:15"
Quote from: tan top on May 01, 2011, 05:08:29 AM
don't think you have a cast crank in there looking at that balancer ,  not 100% but think all 70 motors got the heavier sixpack rods as standard  , there should be a part number on the back side of the balancer think the later starts with 36 ..... :scratchchin:  best get the part number  from the one thats on there  , think the bolt holes are different for the bottom pulley  & there is a a couple of different balancer hole patterns  ,  i would look for a OEM one as opposed to getting an aftermarket one  , as  i'm sure you would be needing to rebalance the motor to do the job propperly , although these motors are internaly balanced  ,  when your rebuilding a motor you really need the balance  the crank with harmonic balancer  , that your going to use !!    :scratchchin:   :shruggy: i'm no expert  though on this  :scratchchin:
:popcrn:
Looking at Freddy's pics it appears that he does not have a 6-pack rod engine. I believe only the "HP" 375 horsepower motors got the heavier 6-pack rods. This motor coming from a chrysler most likely has the 350 horsepower 440 internals with a steel crank and LY rods.
Below is a pic of an externally balanced 440 with steel crank/6-pack rods harmonic balancer. Notice the additional weight attached to the face of the balancer  :scope: In freddy's pics this weight is not there so it's not a 6-pack rotating assembly, inmo.  :Twocents:
That being said, any balancer for a forged crank/internal balance will work fine.  :yesnod:
Pic of 6-pack balancer...which is different from Freddy's on the previous page  :scope:
Quote from: Piston_Freddy on May 03, 2011, 06:44:43 AM
That balancer will work fine  :2thumbs:
terrible one
Quote from: firefighter3931 on May 03, 2011, 11:59:39 AM
:iagree: For what it's worth, that's the balancer I'm using.
Quote from: firefighter3931 on May 03, 2011, 11:57:53 AM
:popcrn:
thanks Ron   :2thumbs: for sorting out my confusion
sorry if i confused anyone  :yesnod:
Quote from: tan top on May 03, 2011, 12:32:23 PM
No worries Tan....your advise was partially correct. All the 375hp motors in 1970 got the 6-pack rods, but the std performance 440's with 350hp still had the lighter LY rods and were therefore internally balanced. It does get confusing at times.  :P
The balancer's design/appearance will usually tell the story  :yesnod:
Piston_Freddy
Thanks Ron! Looks like SUM-163383 balancer it is then. Yeah its just a 350hp 440.
Doesn't look like stock chain and sprockets? Engine was built in 2006, so I think I'll leave it like this? Chain has 0.3937 inch play.
Max rim size:15"
Quote from: Piston_Freddy on May 03, 2011, 01:25:51 PM
Doesn't look like stock chain and sprockets? Engine was build in 2006, so I think I'll leave it like this? Chain has 0.3937 inch play.
Freddy, don't worry about the chain...it's fine. That is definately not a stock timing set. The chain is nice and snug on the left side which is the direction of engine rotation. If there was a lot of slack on both sides it would need replacing.  :yesnod:
I doubt that there is much milage on this engine if the rebuild is that recent.  ;)
I see you have some nice Firecore ignition wires on your motor with the MSD pro-billet distributor. That is an excellent setup !  :2thumbs:
Piston_Freddy
Thanks Ron! Yeah ignition system works fine! :coolgleamA:
Big thanks to moparsal again, i have all the parts i needed thanks to him.
Summit balancer,Percy's header gaskets and carb calibration kit.
Got new valve covers and air cleaner, looks better with black engine compartment and now the 1/2 carb spacer fits.With the old air cleaner the hood was against it(torker intake).Old cleaner and covers are gonna go on a '70 Charger.
Taped a camera on the dashboard and went for a drive: http://www.youtube.com/watch?v=eYap_Vtq9Kk
There is a hesitation off idle and when the secondaries come in. :scratchchin:
Max rim size:15"
