8 3/4 to dana60
Started by alfe, December 31, 2010, 12:00:43 PM
alfe
will driveshaft fit when i swap to dana60?? from 8 3/4
maxwellwedge
Fit what? What car, year, trans?
alfe
Quote from: maxwellwedge on December 31, 2010, 12:07:14 PM
if i change from 8 3/4 to dana 60
68 charger  trans 727
alfe
Quote from: alfe on December 31, 2010, 12:12:48 PM
do i need to shorten driveshaft
Doing a little research in my '69 parts book I found this...
(W) meaning Coronet (same as Charger)
measured from center to center of joints
So YES you will have to shorten the shaft
When going from an 8 3/4" to a Dana the driveshaft will need to be shortened 1 1/8".
The factory specified different driveshafts according to the type of U-joint but the difference between the two center-of-axle to center-of-ujoint dimensions is 1 1/8" so that's close enough.
alfe
69rtse4spd
When I did this on my 69 back in the early 80s, used the same driveshaft. Held up very well even at the drag strip, never had a problem. Doing the same thing in the 70 right now, going to use the same shaft I have right now, as long as the u-joint is the same.
What probably happened in your case was that you took up all the "slack" (for want of a better term) in the slip yoke at the back of the transmission.  There should typically be about an inch before the yoke bottoms out in the trans.  By using up that inch you could make a longer driveshaft fit but the slip is there for a reason.
Lots of people have just shoved the extra inch plus into the trans but they risk damaging the transmission tailhousing. (and the damage won't always be apparent)
69rtse4spd
Has anybody ever thought of just maching off an inch from the slip yoke end. :shruggy:.
tatrick2me
Quote from: Just 6T9 CHGR on December 31, 2010, 01:40:30 PM
Wrong! B body cars with 727's or 4 speeds use the same drive shaft with 8 3/4 or Dana 60. Been there done that.
Bone 7
Quote from: tatrick2me on January 04, 2011, 10:48:44 PM
But have you done it correctly?  :shruggy:
six-tee-nine
IIRC there is no lenght differece between an auto or manual setup. But as Chris stated the manual displays a different lenght for the Dana rear.
So if i'm right there are 2 possible lengths in this case :
1) Auto or 4speed with 8-3/4
2) Auto or 4speed with Dana 60
As Stated above, it wil most likely be possible to mount the longer driveshaft in between the trans and the Dana but then you will just slide the yoke deeper in the trans. Remember that this is no good since the length of the driveshaft alters under the travel of the suspension.....
Offtopic :
I've seen several guys with lifted 4x4's with their original drive shafts who popped their yoke out of the trans on fully travelled out suspension.....
BrianShaughnessy
Quote from: six-tee-nine on January 05, 2011, 07:19:27 AM
1):  The Dana is about an inch "longer" from axle centerline to yoke centerline than the 8 3/4.   The trans makes no difference.    While you might actually get a longer driveshaft in while up on a lift or something,   once the suspension starts working the longer shaft will bottom out on the slip yoke at the trans tailshaft at the seal area probably causing damage.
There's a chart in the Charger, Road Runner and Super Bee Restoration Guide attached.
2):    A Plymouth is about an inch shorter wheelbase than a dodge.   A Satellite / Roadrunner / GTX  8 3/4 driveshaft is pretty close to a Dodge (Coronet / Charger ) Dana 60 shaft - but not quite.
3):    A 70 shaft is 3.25" diameter as opposed to a 69 down 3" diameter.    Bigger is better.  More strength, less vibrations.
4):    40 year old shafts suck.   Buy new.    The last of the driveshaft shops in my area stopped doing them several years ago... which is just as well.  Anything I had done there sucked.
Thanks for that pic Brian....gonna save that one :cheers:
hemi68charger
Quote from: Just 6T9 CHGR on January 05, 2011, 09:18:02 PM
Which pic Chris? The application chart or Brian's signature/avatar pic........   :icon_smile_big:
Houston Mopar Club Connection
bad88t-top
Great read here guys.  Thanks for the info.
TX9 70 Charger RT: 6 pack, 4 speed, A33 Saddle interior, red stripe
EB7 70 Charger RT SE: PS, PB, PW, PSunroof, Defogger, Air, loaded
FC7 70 Charger RT: 440 4 speed, Dana, white longitudinal, black vinyl
EB5 70 Charger RT: 440 4 speed, Dana, B5 interior, white long stripe
EB5 70 Charger RT SE: V code 4speed A34, charcoal interior, loaded
F8 69 Charger: Power Sunroof Car
13 Duramax 2500HD: Tow Rig
17 Durango RT
