Shop heater
Started by Silver R/T, November 28, 2010, 09:23:15 PM
Silver R/T
With cold season outside I was wondering how you guys keep your shops/garages warm inside when you work inside. For me it's impossible to work since it's so cold. Having a kerosene space heater is no option as I don't want to suffocate. I was thinking having a radiant natural gas heater like shops use, would have to pay someone to run piping to it and all that...
What do you guys have?
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
skip68
Yeah, I would stay away from kerosene heaters period! (for any room/garage, whatever.) we just lost the caretaker of my in-laws N. California ranch due to esphexia. He apparently was sick with a bad cold, turned on his heater in his rv (portable heater), and never woke up. Neighbors found him two to three days later in his bed. Very tragic. Propane is just as deadly in a small space if you dont have proper ventilation. I personally just turn on the clothes dryer in the garage!!! Lol! Mrs.skip68
I got a house furnace that I have running on a 5 gallon can of diesel... runs all day on 5 gallons
tall greenish thingy against back wall next to air compressor
The70RT
Wood for me,  just collect it when they clear for powerlines. They will cut in up for you too.
Old Moparz
I've been researching heat for the garage too, but haven't done it yet. The reason for me is that it'll require a lot of work in addition to the heating system. In New York state we have to follow the energy code to be able to install the system. That means a certain R value must be met by insulating the garage. This isn't a problem, but I want to install the system legally by getting a permit & a CO (certificate of occupancy) when I am done. This way the insurance company won't have an excuse to reject a claim if I ever need to file one if I were to have a fire.
I'd have to install some additional electric, rough in plumbing so I don't have to rip open walls later, & actually do all the drywall to cover the insulation. I'd have to empty the entire garage to do this & not ready to yet. Besides, I can't afford it.
However, if I did get the chance to heat the garage, I'd look into something like this, but a shorter version....
http://www.gasheaterstore.com/Infrasave-Gas-Fired-Tube-Heater--155000-Btu--50-long--Natural-Gas_p_393.html
I have propane for heat in my house & like that this type of system is one that has the flame sealed. It will never come in contact with flammable fumes like gasoline. Even the most careful & cautious person can still have an accident like tipping over a gas can or getting a fuel leak & not know it.
               Bob
              Going Nowhere In A Hurry
adauto
Quote from: skip68 on November 28, 2010, 09:45:08 PM
Got that right! I bought a chimneyless Charmglo a few years back to suppliment heat in our sales area at the shop. Only used it a few times, and you really dont notice how bad it is if your working in the room when you fire it up. But go in the shop for 20 mins and come back in..... probly took a year off my life!
Never too many! 70 Chally R/T Convert-70 GTX-68-69-74 Charger-68 Dart GTS
http://a-dauto.com/  http://www.facebook.com/pages/A-D-Truck-and-Auto-Parts/67427352555?ref=hl
KSChrgr68
im installing a potbelly stove my grandfather had in his tractor shop, in a corner on a brick platform, out through the roof with some pipe, boom, instant heat and an endless supply of wood nearby.   :icon_smile_big:
I got my dreamcar in 2010
bull
I got one similar to this on closeout a couple springs ago at Lowe's for like $15. It's an oil-filled radiant heater and it works great. Just plug it in and turn it on. If one is too small for the amount of space you have, buy two.
The70RT
Quote from: bull on November 28, 2010, 11:25:39 PM
I run one like that when I am not in the garage just to keep things from freezing. It keeps my 26X32 garage like 50 when it is in the teens. It works better when you run a ceiling fan right above it.
Todd Wilson
I got a natural gas furnace in my garage. Works great.   If one is going to build a new shop go with radiant floor heating and put insulation down under the floor and pipes.
Todd
Khyron
I got a fuel Oil heater from a old trailer, it's a 2 year old miller... should do be fine, just got to hook it up.
HERE, HERE, AND HERE.
Domino
Put a magic pak unit in my shop and Dad's shop. Works great.
http://www.magic-pak.com/products.php
elacruze
We installed a take-out home furnace and had it converted to Propane, dropped a 500 gallon tank behind the building and ran it for 3 years. Much nicer than feeding the 55 gallon drum/chimney monster before that.
1968 505" EFI 4-speed
ITSA426
I have about 400 square feet of garage so I don't want to give up any room.  When remodeling started I had several electric mats put into a sand bed eight inches below the concrete floor.  Two inches of foam insulation surround the sand bed at the garage exterior walls.  There are several different mats made just for this application.  Segments are wired in parallel so if one fails everything else still works.  I got them connected to my electric company's off-peak system so they are powered from 11PM to 7AM at off peak rates.  The mats warm the sand, the sand warms the floor.  The garage floor is 71 degrees this morning.  It looks like about $2/day to keep it warm but the install, with commercially installed floor coating, was expensive.  No fan, no flame, no noise and you can walk in the garage in stocking feet all winter.  Soap and water clean up.
It may be eligible for tax credit in other installations but I replaced and upgraded a bunch of other stuff any ways.  Check to see if you electric company has an off peak system.  This assumes you're going to be staying where you live.
69 OUR/TEA
I was fortunate that when I was building the addition on my house which consisted of a 30 x 44 garage with all living space above which is also the same dimension,and wanting to not be above a 30-40 deg cold garage,I knew it should be heated,and being fresh from ground up,I went with radiant floor heat in the concrete slab  getting the hot water from my boiler.
I realize that most are not going to chop up their slab to put it in,but if anyone is building a new garage,I would highly recommend researching it,as it runs so efficient.People that come over come and realize its warm,look around and wonder where the heat is coming from.I keep it at 61 in there,and being radiant heat,everything in the garage is uniform temp.
Todd Wilson
Quote from: 69 OUR/TEA on November 29, 2010, 11:49:33 AM
That radiant floor heating is awesome.   Theres a lot of low to the ground working on vehicles.   Even with my natural gas furnace  it can still be cool down low to the floor.   Stuff is just warm with the radiant floor. Friend has one in a big shop and its awesome.
Todd
I've got two of these in my shop, natural gas 140K BTU's (don't look at the meter while one is running). Best part, both were given to me because they needed work..about $50 worth each.
flyinlow
I have a 30x50 garage insulated to r 25. A 55.000 BTU forced air furnace rejetted for propane. 92% efficient . Breaths thru pvc pipe so no inside vapors can get to the flame. Programable thermostat resets the temp to 45*F every six hours. I you want more heat you bump it up and it stays there until the next program reset to 45*  Basic ductwork .four 8 Inch ducts distribute the warm air. No cold air duct ,just a hardware cloth cage on the bottom to keep debrise out plus a filter on the furnace. Temp. in the garage increases about 1* per minute when it is running. Switch on overhead door to kill the heat when the door is open. About $200-$300 per season to heat in Ohio .More  if you paint alot.  Shares the propane tank with the house.
bill440rt
My attached garage is about 25 x 30. I have one of those little radiator heaters like Bull shows, it works OK if you are standing right next to it. Needs some time to warm up, but it works OK.
To supplement that, I also have a kerosene heater I bought at Home Depot for under $75. Works great. Garage will get nice & warm, at least comfortable to work in. I keep a window cracked open just slightly for air.
Are kerosene heaters that bad??  :scratchchin:
elacruze
Quote from: bill440rt on November 30, 2010, 07:46:59 AM
I had more than a couple kerosene heaters, from torpedos to radiant-I hated them all, every one is noisy and stinky.
For the most part in the winter I try to work in a smaller shop in the backyard and that has electric heat in it.  The garage itself if I have to move in there for something I use a portable propane unit and if I really big stuff to do I go to a shop I share with a friend and it's natural gas but like John says, don't look at the meter while it's running.
NHCharger
I had this 75k BTU Hot Dawg propane heater installed six years ago. Heats my 30x50 shop with ease. Have not had any issues with it.
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone
2014 RAM 2500HD Diesel
71green go
Quote from: A383Wing on November 28, 2010, 09:48:07 PM
I do the exact same thing....
bought a used high eff oil furnace from paper c/w tank...$150
bought used stainless chimney pipe $175
run on diesel fuel...........oil heat is so nice and warm compared to propane which I had in my last shop....
5 gallons diesel runs 8-10hrs...i only heat shop when I am in there
love it
BlueSS454
Can you give a little more info on this?  I see these all the time on Craigslist and I'm thinking it might be a good option for my 30 x 40 pole barn shop.  I'm a little uneducated when it comes to these things.  Does it need electric (110 or 220?), also guessing it needs to be chimneyed to the outside.
Tom Rightler
yes...it needs 110v.....and it needs to be exhausted outside....(mine is exhausted through the roof)....the pic I have above is when we moved in...it's not up & running in that picture....I'll be out in the garage this weeknd...I'll take some detailed pics of completed installed furnace
Bryan
BlueSS454
That would be awesome, thanks!
Quote from: A383Wing on December 02, 2010, 11:43:49 PM
Bryan
Tom Rightler
DonC1
Here in Canada..just north of Seattle 100 miles I have radiant floor heat run by a water heater. With the new 'bend you over the coals'
local BC hydro two tier system..ie if you use more electricity than a one room apartment per month your instantly over billed. So my great floor heat (and boy it sure was nice) now costs me on average 300-$400 per month during winter.
Too much. Sounds like the floor mat heat pads are a great idea and or propane.
ITSA426
DonC1 See if your electric company offers an "off-peak" rate.  There are also interruptible rates that allow the power company to shut off that item when demand is high.  My brother uses that for his water heated floor boiler and it hasn't been below his thermostat setting yet.  He pays a penny or two more than I per KWH. He is heating 30' X 45' but the water heated systems do not qualify for heat storage rates if the water is in the concrete rather than the sand bed below it.  My floor is heated for eight hours a night but it takes a long time to give up heat from the sand and concrete.
There must be something.  I understand a lot of our electricity is generated in Canada.
Quote from: BlueSS454 on December 02, 2010, 11:04:38 PM
Ok...here are pics & info as promised.....furnace is downdraft style, meaning it draws air in the top and blows it out the bottom. We put furnace on a home made stand and cut 2 sides out of it so heated air will come out. I have a 6 gallon plastic diesel jug that has suction and return line going back into it. Be sure to run an inline filter on suction line. Outlet for burn side of furnace is going up and through roof, and stack is outside garage. Also have thermostat at workbench...make sure it's one that can be turned off all the way to the left..if it can't be turned off, it will get cold enough that furnace will turn on when cold temp is reached. I only turn it on when I'm out there, no sense in wasting diesel fuel when it's $3.50 a gallon out here. All power for furnace is from standard 110v house current.
Furnace brings 5 car garage up to almost 60* in less than an hour...I can run all day on less than 5 gallons of fuel.
Silver R/T
2001 Ram 2500 CTD
BlueSS454
Thanks for the info!  That's a pretty nice setup, doesn't take up a lot of room and is pretty basic.  I think I'll be looking around on Craigslist for a used oil furnace  :2thumbs:
Tom Rightler
