727 HD transmisson
Started by bobfist, October 28, 2010, 03:10:23 PM
RD
Quote from: bobfist on October 31, 2010, 03:02:33 PM
ok, so place some more friction discs then, thats what i read
someone has to have a book on the internals on the D32 727 - B
i can understand that you want originality... but bob... no one will inspect the inside of your transmission if you plan on showing it.  As long as it looks original, that is all that matters.
here are some pics.  they all look the same generally.
bobfist
Thanks, ill see what i can do :)
i think i place four discs instead of three then
www.bobfist.com
Muscle Car Restorations & Reproduction
Sweden
RD
Quote from: bobfist on October 31, 2010, 05:01:51 PM
its not that easy.  you need the appropriately sized pressure plate to accommodate the extra disc and steel (i.e. a thinner pressure plate than a 3 clutch disc pressure plate).
bobfist
Looks like an HD transmission anyway.
Yellow paint, 4 discs in every drum and 4 pinion in front and three in back
www.bobfist.com
Sweden
RD
there ya go.  if you have any questions on the overhaul.. you can always ask them here.
