727 HD transmisson
Started by bobfist, October 28, 2010, 03:10:23 PM
bobfist
Hi!
i want to know what the difference are between a A272 and a a A727 HD 1969
And wonder if the Charger 69 RT/SE came with HD Shocks?
www.bobfist.com
Muscle Car Restorations & Reproduction
Sweden
Brock Samson
 as to the shooks yeah they came with heavy duty Monroe shocks. yellow in color as i recall. there is a truck trans and a later over drive trans though I'm not an expert.. they will chime in soon I'm sure..
RD
Quote from: bobfist on October 28, 2010, 03:10:23 PM
Hi!
how do you know its an HD?  the difference is many, but its based upon the make/model.  what are the numbers on your transmission?  John_Kunkel has said this many times (and I am paraphrasing, but its the truth):  the 1969 transmission is 41 years old, that is a lot of years for people to tamper with what originally came in it.. so who knows what is in it now.
bobfist
what i meant is how the parts internal are different
www.bobfist.com
Sweden
Sometimes they have an extra pinion in the planetary set or an extra disc in the clutch pack but as far as any hard components being altered for extra durability such as high strength input shafts or thicker cases, there won't be things like that.  If that is what you are asking?
bobfist
ok, so how the stock 440 4-barrrel HD transmission was build are impossible to find out?
B&M have a HD transpack but thats not the thing i guess?
www.bobfist.com
Sweden
The question is hard to answer in detail without a specific year.
In any given year the difference between a standard 727 and a HD 727 depends on the motor it was attached to i.e. a standard 383 trans would be different than a standard 440 trans and in some years a HP 383 trans would be different than a HP 440 trans but in some years they're the same.
Confused yet?
bobfist
i read somewhere that hd 727 on 440 hp engines had four pinions instead of three
www.bobfist.com
Sweden
RD
Quote from: bobfist on October 30, 2010, 04:43:03 PM
some did.. in the front planetary, and some did in the rear planetary.. but some had 4 in the front and 3 in the rear... :D
bobfist
oh god, never gonna build this like the Hd original .... :(
www.bobfist.com
Sweden
RD
Quote from: bobfist on October 30, 2010, 04:53:45 PM
a stock 727 can handle up to 500-550hp.  how much more HD do you need?
bobfist
no im not out for Hp just to build the stock transmission code D32 in my papers from factory.
www.bobfist.com
Sweden
Why worry? Nobody can see inside.
The weakness in the planetaries isn't in the pinion count but at the spline in the front planetary that mates to the output shaft.
bobfist
ok i will stop worry, but must be many members in here that dont know if their 727 are Hd then?
www.bobfist.com
Sweden
The part number stamped on the pan rail determines whether or not it started life as a HD but, like RD noted, after 40+ years who knows.
bobfist
yes, that number says 1970 C-body 440 350 hp
www.bobfist.com
Sweden
RD
Quote from: bobfist on October 30, 2010, 05:02:16 PM
actually, there are many members here who have transmissions that are "more" HD than came from the factory LOL!
oldkimmer
............A hd input shaft from the factory will have a dallop of yellow paint on it..........kim..............and yes ive had a few................and still do.........
Back in the good old days 1968 charger rt 440 magnum . 1968  charger 383 magnum. The Beast has been Unleashed!!!!!!!!!!!!!!
Is it the shaft that's different though or does the yellow paint indicate the the trans as a whole is hd?
For 70 I've run across items listed as "For Six-Pack or Hemi" from suppliers on eBay also.....so HD tranny is like HP blocks? (internal parts changed but no "basic" difference)   :shruggy:
RD
Quote from: b5blue on October 31, 2010, 06:13:09 AM
yes and no.  a hemi transmission is the only transmission to have the larger intermediate band, and front drum (think more surface area).
you are correct with your assumption in regards to your HD / HP analogy though.
bobfist
But in my papers i can read that my option D32 are a 727-B transmission...
Need to find anyone that can rebuild it just like original
www.bobfist.com
Sweden
Rebuilding it like original is easy for most any competent trans shop.  They aren't going to need to replace something like a planetary set for example (unless it's broken).  They are going to primarily inspect, replace wear items like bands and clutches and reassemble.
bobfist
ok, so place some more friction discs then, thats what i read
someone has to have a book on the internals on the D32 727 - B
www.bobfist.com
Sweden
Quote from: oldkimmer on October 31, 2010, 12:08:14 AM
Ma was very inconsistent about this, some years have the yellow paint and some years have a shallow groove in the splines, some have both and some have none.
The shaft in the pic below has both the groove and the yellow paint.
RD
Quote from: bobfist on October 31, 2010, 03:02:33 PM
i can understand that you want originality... but bob... no one will inspect the inside of your transmission if you plan on showing it.  As long as it looks original, that is all that matters.
here are some pics.  they all look the same generally.
bobfist
Thanks, ill see what i can do :)
i think i place four discs instead of three then
www.bobfist.com
Sweden
RD
Quote from: bobfist on October 31, 2010, 05:01:51 PM
its not that easy.  you need the appropriately sized pressure plate to accommodate the extra disc and steel (i.e. a thinner pressure plate than a 3 clutch disc pressure plate).
bobfist
Looks like an HD transmission anyway.
Yellow paint, 4 discs in every drum and 4 pinion in front and three in back
www.bobfist.com
Sweden
RD
there ya go.  if you have any questions on the overhaul.. you can always ask them here.
