Horn help please-
Started by WV69RT, October 07, 2010, 07:46:17 PM
WV69RT
I'm having horn troubles.  It went from working fine to suddenly constant blowing, then nada. I've ordered the horn ring for the steering wheel and the horn relay.  Today I received and replaced the relay and I got the constant horn. So, I'm theorizing that the horn button is stuck. That's what blew the relay in the first place.  So what do you guys think?     :scratchchin:
Long Island RT
Sounds about right - I believe the horn button works as a ground - so anywhere along the line - if the wire feeding your button is grounded - you'll be constantly horny.
1969 Dodge Charger RT Restomod<br />Triple Black, 512 stroker, Tremec TKO600 5-speed<br />2005 Dodge Magnum RT - Brilliant Black - Lowered
Quote from: Long Island RT on October 08, 2010, 01:39:45 PM
interesting  :scratchchin:
:rofl: :rofl: :rofl:
seriouslly.
wire cover it can be broken and grounding around inside the column
nvrbdn
had that happen once when the wire solder came loose and the wire made constant contact under the horn button. untill i could get it fixed i took the button off and would have to hold the wire to ground to honk. :smilielol:
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
WV69RT
Just received the new horn button... Should have an update this week.   :eyes:
WV69RT
Update---
   Both the new relay and button are in... I get a constant beep.  So I have a grounded wire somewhere.  Another thing is my horn only works with the car started. I don't think that's how it was in '69 was it?    :brickwall:
no, is battery feeded, no key needed.
I would say more WRONG wired...
check the wire coming from cab at relay if has continuity with chassis
mysil bergsprekken
Quote from: Nacho-RT74 on October 23, 2010, 11:13:28 AM
Right no my horn doesn't work at all, but is it really supposed to work with the car not running? I believe I have to turn the key to "acc on" or "ignition on", whatever you prefer, to get the horn provided with power.  Is it supposed to get power without even turning the key. Just by pressing the horn button?
69 charger RT
doctor4766
Quote from: mysil bergsprekken on November 30, 2011, 02:44:18 AM
Yes
Gotta love a '69
