smooth 440
Started by ionracer24, August 22, 2010, 08:56:55 PM
ionracer24
ok, so i got a 440 and here's whats stamped on the pad
4 T 440 t
7  8
so what do i have???
Real race cars have three pedals......
captnsim
Truck block made in Trenton on July 8th 1974
ionracer24
thank u very much captn,  there's not a difference between car and truck blocks is there???
ionracer24
stripedelete
Quote from: Ghoste on August 23, 2010, 05:48:32 AM
No difference.
So why did they designate it as a truck block?
ionracer24
Quote from: stripedelete on August 23, 2010, 02:46:19 AM
No difference.
Good question... so the 74 blocks are the thicker ones correct????
bricklayer
No thicker and no higher nickel either as far as I know.  I realize there ate a lot of myths floating around about that but to my knowledge any tests that anyone has done in the aftermarket haven't born them out.  I think 440source have a lot of better block info on their site.
ionracer24
Quote from: Ghoste on August 23, 2010, 08:15:04 PM
thanx Ghoste,  i was thinkin that i read somewhere that 75 and later blocks had thinner cyl walls or something.....
Sixt8Chrgr
Quote from: ionracer24 on August 23, 2010, 09:26:33 PM
Read the info on the 440 site about blocks. It is a great read, and you will be surprised of their findings.
ionracer24
Quote from: Sixt8Chrgr on August 23, 2010, 09:30:10 PM
:cheers:  thanx for the input guys, i was also wondering where i can get stock replacement rocker arms and rocker shaft as well as the bolts and keepers??
Cooter
The only difference I've noticed with the "truck" blocks is the Figure * coolaing passages in the deck surface.
Quote from: ionracer24 on August 23, 2010, 10:12:51 PM
Mancini Racing
ionracer24
Quote from: b5blue on August 24, 2010, 05:27:34 PM
Mancini Racing
thanx blue!!! thats just what i needed!    :cheers: :2thumbs:
Got them there too.   :cheers:
ionracer24
how much hp do u think the stock piston rods can hold??
