cam question
Started by 68chargerboy, July 22, 2010, 10:24:30 AM
68chargerboy
do these cam specs seem like a decent cam for my combo, 505ci, twin turbos, stealth heads, torker II intake, 4.10 gears, still debating on tq stall, shootin for around 7-800hp, thanks in advance
Zach
251-262 @.050
556-577 lift
114 LSA
frederick
You'd want a custom cam for a turbocharged engine.
You don't give enough information of the camshaft to make a decision.
You need to look at the opening and closing points instead of looking at the duration.
Normally you want to delay the intake opening 20-25 degrees compared to an N/A engine, exhaust opening should also be later.
Suggest you contact Mike Jones.
http://www.jonescams.com
Cheers,
Frederick
