Actual engine temp
Started by Paul G, July 17, 2010, 07:07:18 PM
Paul G
I am finding with the summer heat in full swing my 72 is running very hot with the A/C on. By very hot, I mean the temp gauge in the car is going over 225 toward 250. I am starting to worry.
I took my digital laser thermometer out and took some temps of the engine while idling, A/C off. It will cool down a bit with the A/C off. The T-stat housing/water neck is reading 205, temp sending unit is reading 195, and the gauge in the car is at 220. I have Auto Meter gauges in the dash. 160 T-stat is brand new, a full bottle of Water Wetter in the radiator. And it is around 110 outside right now. Stock radiator with stock shroud and fan/clutch.
Could the dash gauge just be reading a little hotter than the actual engine temp?
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
1970Moparmann
You answered your own question.  The gauge should read where the temp sensor is.  If your engine was at 250, you would have had some serious results.  :yesnod:
histoy
Your Auto Meter gauge may not be compatible with the temp sending unit in the car.  I would check with their tech people.
Quote from: 1970Moparmann on July 17, 2010, 07:18:24 PM
Exactly....the guage is reading incorrect for some reason.  :yesnod:
