Alignment question
Started by bricklayer, May 31, 2010, 07:00:06 PM
bricklayer
69 charger, done with front end rebuild before i take it to an alignment shop in what order  should i start with tbars then tierods then upper control arms then what? or upper contrl arms then tbars etc.. just not sure the best way for the intinal setup before i take it to shop thanks  tom
I set front end height at the lower control arm adjusters per the FSM at home first as changing that later will alter everything a little everywhere.
elacruze
 :iagree:
Set your ride height, eyeball camber to zero then set the toe to as close to 1/8" in as you can get it with your measuring device and go to the alignment shop.
1968 505" EFI 4-speed
HPP
Set the ride height first , but I'd recommend you not listen to the FSM as it will likely set the nose a tad bit higher than you want it. Also, when you get it aligned, do not use the stock specs unless you have a manual steering car or are using repop bias ply tires. If your using radials, go for as much positive caster as possible up to 5*, cmaber of  negative .5*, and total toe of .0625. This will result in a much better behaving road car than the stock specs.
bricklayer
thank you for the replies i will use them wisely, working 4 ten hour days so that leaves me the whole day friday to work on my car!!!! wife is at work kids are at school. i figure all i have to do is get one thing done on my car each week and soon i will be able to ring it's gut's out but not to exceed recomoned rpm to horsepower ratio.    thanks  tom
GMachineDartGT
First thing to do is make sure the lower control arms are square to the chassis and that the axle is square to the chassis. All other measurements are useless, until you know if everything is square. After that, rough setting height is possible on the ground, but really needs to be done on the rack, if it is known to be level. Any corner of the car that is not on level ground will change your height measurements.
